Yes
You're getting there Cleve.
Be sure to have the upper fiberglass ramps glassed to the upper cowl and fit the side baffles accordingly.....patience/fit/cut/fit/cut. When you start attaching the rubber baffle material, cut it across the narrow width. That will provide an automatic inward curve since it was rolled and will keep that shape. Regards, Pierre |
Initial baffle cut
There is a trick for getting the initial cut.
Install the uncut baffles. Take four paint stirring sticks or similar. Raise the top cowling about 6 inches above the bottom cowling and clamp in place using the paint sticks to create four "legs". (Clamp sticks to the outside of the bottom using c-clamps or similar and likewise on the outside of the top piece.) The top cowl is now "floating" above the bottom cowl. Wish I had taken pictures. Now, adjust so the spacing is consistant all the way around. Six inches is a good amount (std steel rule). Make sure the top is directly above the bottom and not skewed fore/aft, left/right. Now you have room to get your arm in there. Tape a Sharpie exactly 6 inches down another paint stick or similar. Now, reach in and hold the Sharpie stick up against the inside of the top cowling and run the marker along the baffles. If you kept the stick vertical, you now have a pretty "exact" line representing the contour of the inside top cowl on the baffles. Cut along the line (or if you're real gutsy, go ahead and move the line down the "gap" amount". You can also add the gap to the marking stick). This will get you very close to the final fit. Somebody must have pictures of this. Once you see it you think "of course!". |
Very good!
Outstanding piece of advice, Mike. Were you ever a wooden boat builder? They use many similar helpful techniques.
Thanks, Pierre |
Timely Info
I'm always amazed that this info seems to pop up at just the right time. I hope to start baffles in the next week.
Dumb question.....
Why doesn't someone mold a crystal clear cowling that could be used in this process?
Granted, I have never done baffles, nor am I anywhere close to doing them. But it appears to me that the largest part of the process is guesswork as to where to trim, how much to trim, etc. What if there were some clear cowlings strictly for this purpose, based on each RV model. It seems to me someone could make a nice little living by shipping these cowls around for a fee, and the people doing baffles could actually see where everything was lining up? I know cowlings are somewhat different, as far as actual final fit, how much you trimmed yours versus the next guy. But, if you had some sort of a visual gauge system on your first set of baffle material, you could install the 'somewhat universal' cowling, then look in there...."OK, reference point #1 needs about 1/2" cut off. Moving up to reference point # 2, we need about 1/4" cut off", etc. Just a thought....from someone who has never been through this process. :confused: |
Nice!
Excellent tips, Claude. Thanks for sharing the exact process!
Take care, |
| All times are GMT -6. The time now is 07:41 PM. |
