For those that are AP's - O-360-A1A questions...
1. When should you replace the spark plugs? At a Hour mark (400 hours)? or just want until they fail the testing tool?
2. O-360-A1A with slick mags ... do they need a rebuild at 500 hours? or just do they need to be cleaned and retimed? |
The later model mags (4300 series is the most current) have a 500 hour inspection interval. Complete the inspection and replace any parts determined to need replacing, and you should be good to go for another 500 hours. |
Slick Maintenance Manual
Superior has kindly published the Slick Magneto Maintenance Manual (not available on the Unison site... :) ...) here.... http://www.superior-air-parts.com/Do...%20rev%20A.pdf It's Appendix 1. gil in Tucson |
Thanks Gil ... thats just what i was looking for! :)
I would recommend replacing the points while you have the mag open for the 500 hour inspection. It's cheap insurance to help you get through the next 500 hours. |
| All times are GMT -6. The time now is 05:58 PM. |
