VAF Forums
-   RV-7/7A (https://vansairforce.net/community/forumdisplay.php?f=7)
-   -   Access plate assembly (https://vansairforce.net/community/showthread.php?t=20281)
llarkin 08-07-2007 04:02 PM
I am currently working on the bottm wing skins where the W-822 access plates attach. My question is: Does the W704 and W705 wings skins get machine cntsnk or dimpled where the rivets attach the K1100-08 plate nuts?
Thanks in advance,
Larry in Loveland, CO
tomcostanza 08-07-2007 04:18 PM
Hi Larry,
I've been countersinking for NAS1097AD3 rivets. They have a VERY small head, but the rivets that hold the nutplates only need to hold them while you're threading the screw into the nutplate. Then the screw holds everything together. Since the rivet head is so small, you don't need to remove much metal. A few turns with a deburring tool is all it takes.
Hope this helps.
llarkin 08-07-2007 06:30 PM
Thanks Tom, Should I use the same method if I were to use the rivets that Van's calls for with the standard head?
Larry
cln1owner 08-07-2007 06:45 PM
Larry
Larry,
I would dimple the skin and the platenut if you were to use the regular AN426AD3 rivets since you would have to remove too much material to get the rivet head flush, resulting in an enlarged hole in the skin. You want some skin material remaining around the shank of the rivet. Only machine countersink if your going to use the NAS1097AD3 rivets...
JohnR 08-07-2007 07:11 PM
Larry, I have done most of my nutplates with the same rivets mentioned. I picked mine up at https://www.pegasusautoracing.com/pr...uct=NAS1097AD3
They have a much smaller head than the ones Van's provides and therefore can be countersunk into thin material easily ans safely.
