VAF Forums
-   Propellers (https://vansairforce.net/community/forumdisplay.php?f=19)
-   -   Hartzell prop weights (https://vansairforce.net/community/showthread.php?t=2022)
rv6ejguy 06-17-2005 10:02 AM
Anyone know what the typical Hartzell C/S prop for an IO-540 weighs?
Rotary10-RV 06-17-2005 01:39 PM
The O and IO-360 (200 HP)props weigh 50-55 pounds according to Vans. The weight shouldn't be more than 10 pounds more max. They don't list the RV-10 prop yet.
Bill Jepson
randylervold 07-19-2005 01:45 PM
A 72" compact hub, complete with Van's spinner and hardware, weighs 59 lbs. Not sure what prop is specified for the RV-10 but I suspect it's an 80" or so and would be several pounds heavier.
osxuser 08-16-2005 11:33 PM
I suspect a 2-blader would be between 55-60LB and a three blade to be 70-80LB.
