VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   Screen, for you engine experts (https://vansairforce.net/community/showthread.php?t=19461)
JonJay 07-12-2007 09:57 AM
Simple question - does an I0360B1B have a screen or does the oil filter take up that job? Cant' seem to find in my Lyco manual.
Mark Burns 07-12-2007 10:43 AM
There are others here more qualified to answer but,
The oil fliter takes the place of the oil screen.
There will still be a suction screen in the sump though.
Mark
JonJay 07-12-2007 10:54 AM
Mark
Thanks. That is what I thought. I assume that the sump screen is only serviced upon overhaul?
Ron Lee 07-12-2007 04:11 PM
I don't know what the official servicing period...
for that sump screen is but I will check it on each oil change with a new engine now that I know about it.
az_gila 07-12-2007 05:14 PM
100 hrs.....
My O-360 Operator's Manual calls for cleaning of this suction screen as a 100 hr inspection item....
gil in Tucson
robertahegy 07-12-2007 06:10 PM
The screen should be cleaned at least every 100 hrs. They can plug and you will fry your engine.
Roberta
David-aviator 07-12-2007 07:14 PM
Roberta
Yes, and if the pieces are large enough to get caught in the screen and are not sludge, it is time to determine what is going on. Lycomings are great for sending messages long before they give up the ghost.
Not an expert opinion, just a regular opinion about the ol' beast. :)
az_gila 07-12-2007 07:42 PM
Order a new gasket first....
Roberta
...and don't forget to buy a new STD-111 (or MS35769-21) copper crush gasket first.... the old gasket should not be re-used....
gil in Tucson
Mark Burns 07-12-2007 09:15 PM
I agree with everything that has been said
Since I was the first to get an answer in I just thought I would say that I agree with every post that has been made after. :)
Mark
cbo111 02-01-2008 08:33 PM
Same gasket for 0-320 B
gil in Tucson
Gil,
Do you know if this is the same part number used for a Lyc 0-320 B and does it look like a small copper ring?
thanks,
Chuck Olsen
RV7A
TSP
