VAF Forums
-   GPS (https://vansairforce.net/community/forumdisplay.php?f=39)
-   -   Avmap question (https://vansairforce.net/community/showthread.php?t=19235)
shiney 07-06-2007 01:25 AM
Avmap question
I'm narrowing down my GPS options, and one of them is AvMap. I have been told that recent reports show the latest firmware update to the AvMap EKP IV messed up the NMEA 0183 data output for the Trio A/P so that it won?t drive the autopilot properly. Apparantly earlier versions worked properly. What is the situation with you AvMap users and has anyone checked with AvMap to see if the firmware version is compatible. I know that Trio have talked with them and they are trying to determine the cause of the problem.
Martin
Pilottonny 07-06-2007 11:08 AM
AvMap = great (do not know about your problem!)
I do not know about this, but I know that the EKP IV has got the largest screen and works great! Great reception, even in the worst circumstances . We have some problems with the Jeppesen data though (is just ****, lots of data wrong and many things missing!! I have not updated for more than a year now , just because of that. Even Jeppesen themselves could not come up with a reasonable answer why the data is just unsatisfactory in Europe.) Apart from that, I would recommend the EKP IV any time. Lots of great features, easy to use and a ?huge? screen for its price.
I am planning to install it in my panel and connect it to a Tru Track auto pilot in my RV9A. I will follow this thread because of that, anyway.
Regards, PilotTonny.
shiney 07-06-2007 11:13 AM
Thanks for that Tony, I know that AvMap users are impressed with the product and less impressed with the data (europe) but it's vital that it talks to the trio, otherwise its of no use to me. Come on AvMap - Trio users, post me your comments.
Martin :)
Mike S 07-06-2007 11:36 AM
Martin, I hope this helps you, although I have TruTrack, not Trio, one of the things I learned while researching things is that the output of the AVMAP can be fed into my GRT setup, and then outputted to the autopilot in ARINC 429.
This makes the auto pilot quite happy.
You didnt mention what EFIS you have, if any, but it may be something to look into.
Good luck,
Mike
shiney 07-06-2007 11:46 AM
Great news, I'm getting the GRT Dual Horizon with WAAS, so this would appear to solve my concerns wouldn't it?
Martin
videobobk 07-06-2007 12:57 PM
AvMap/Trio
AS I posted in a PM to Martin, AvMap gave me an early June version of their software while they fix the newest version to work with Trio. Haven't talked to them since, but they will fix it. The version they sent works great.
Bob Kelly
lucaberta 07-07-2007 07:21 AM
Bob, we're having the exact same issue with a friend's FlightDesign CT here in Italy. His Trio AP does not recognize the NMEA stream at all, and nothing good happens. I did debug the NMEA stream and some fields are clearly wrong, with a decimal dot followed by no digit.
Is this software publicly available, or did Avmap give it to you only on an individual basis? Are you able to tell me the version number and date that shows up on the software information page?
Many thanks,
Luca
shiney 07-07-2007 07:41 AM
Luca, try Dan Lyons at AvMap (US) he's emailed me to say that he will provide me with the older SW until they resolve the problem with their latest version, contact him on 800-363-2627 (US) or email him dlyons@c-map.com
Good luck and let me know how you get on
Martin
lucaberta 07-07-2007 09:53 AM
thanks Martin, I'll email Dan right away and ask him details about the software downgrade.
Just so I know, are there any important features that will be missed should I have my friend downgrade to the previous software?
Thanks, Luca
Mike S 07-07-2007 10:25 AM
Luca----------Have your friend save the existing program to the data card, and use a different card for the new program.
He can then pick which one is best suited for his needs.
Mike
