VAF Forums
-   Propellers (https://vansairforce.net/community/forumdisplay.php?f=19)
-   -   Blade Painting question??? (https://vansairforce.net/community/showthread.php?t=19105)
rscott5559A 07-01-2007 10:39 PM
Ok need some help...
My Catto Prop is almost ready to paint. I want to have it painted black with yellow tips. My paint scheme is going to be a WWII polished and painted P51 style. Colors yellow/black or red/white checkered..... Anyway, my research shows the blades are black and the tips ( rounded ) as yellow on the front. But what about the back side of the tip. Yellow also? Craig says you will probably always see a shiny yellow ring, especially if the sun is behind you.
Anyone out there have some experience with this?
What do you guys think???? :confused:
Thanks in advance
John Clark 07-02-2007 12:33 AM
Backside of the prop
Yes, you will see a circle with light colored and/or shiny tips. There is a reason that almost all the props on single engine aircraft are flat black on the back side.
John Clark
RV8 N18U "Sunshine"
KSBA
