VAF Forums
-   Alternative Engines (https://vansairforce.net/community/forumdisplay.php?f=22)
-   -   Subaru 7A Down (https://vansairforce.net/community/showthread.php?t=19078)
Yukon 06-30-2007 10:14 PM
Subaru 7A Down
Anybody have information on an Egg 7A down in Arizona?
RV7Guy 07-01-2007 12:42 AM
7A Down
Hi John,
What did you hear? When, where?
rv8ch 07-01-2007 03:53 AM
Builder ok
Just picked this off of the Eggenfellner Yahoo group:
Originally Posted by Jan Eggenfellner
Off airport landing with a supercharged 4 cylinder. Somehow the MP went to at least 40" and boost warning lights came on. (We will try to find out why) He throttled back and landed but damaged the airplane and engine.
Builder is in good shape but obviously sad.
Jan Eggenfellner
Yukon 07-01-2007 07:34 AM
Originally Posted by RV7Guy
Hi John,
Roger Everson, yesterday. He's OK, plane flipped. Supercharged 4 cyl.
RV7Guy 07-01-2007 08:48 AM
check your pm's
John,
Check your PMs.
rv6ejguy 07-01-2007 09:13 AM
The Egg STIs have several iterations of the so called wastegate (compressor bleed valve). Some have fitted a cable controlled valve. If you forget to open the valve before closing the throttle, the boost will spike way up because the supercharger is a positive displacement type. Unknown how the stock ECU will deal with this. Typically if it goes way over factory spec, it triggers a momentary fuel cut but shutting off the injectors. There have been several wiring mods to this system and the ECU may not be functioning in the full factory designed mode.
Other engines are using an automatic bleed valve which does not require pilot intervention. This is probably a better idea if it is reliable.
In serious cases, the belt could be thrown if the supercharger sees enough load due to total restriction of the boost air.
gbrasch 07-01-2007 09:44 AM
This was not the case in this incident, Roger was taking off under full power, FYI.
videobobk 07-01-2007 02:09 PM
Glad he's okay
Met Roger last year at OSH, nice guy. Sure glad he's all right, at least physically at the moment. I believe he had the same carbon fiber canopy I have, so I am very interested in how it stood this ultimate test. Anyone know about that? I know he hasn't been flying the 9A long and has to be devastated.
Bob Kelly
MrNomad 07-01-2007 03:29 PM
Bummed out for certain
Originally Posted by videobobk
Met Roger last year at OSH, nice guy. Sure glad he's all right, at least physically at the moment. I believe he had the same carbon fiber canopy I have, so I am very interested in how it stood this ultimate test. Anyone know about that? I know he hasn't been flying the 7A long and has to be devastated.
Bob Kelly
I spoke to Roger's wife just now and he's ok, plane is wrecked. We visited him several times before we started our 9A project. According to his wife, every morning he was out there flying before work and enjoying the fruits of his labor. Obviously, he is completely bummed out after putting in years of work. His wife said the canopy may have saved his life cause he crawled out from under it suffering only scratches (and a major case of depression I'm sure).
Roger did quality work from what I could see.
rv6ejguy 07-01-2007 04:19 PM
I wasn't commenting on the accident as I didn't know the facts. Merely an observation.
The only way boost can increase on a positive displacement blower system like this at WOT and constant rpm is due to either the throttle closing or the bleed failing to stay in the control position.
Since these engines use a fly by wire throttle controlled by the ECU, several inputs could have the effect of closing the throttle without pilot command.
Very glad that Roger is ok and hope he decides to repair the RV with his wife's blessing.
