VAF Forums
-   Primers (https://vansairforce.net/community/forumdisplay.php?f=54)
-   -   what primer do you recommend? (https://vansairforce.net/community/showthread.php?t=18964)
ditch 06-26-2007 05:09 PM
Just ordered the empanage kit and I was wondering what primer works best and where can you get it? Tools and kit should be here sometime next week and I wanted to get primer so I can start right in. Also, is there a cleaner thats used with it? Any info is appreciated. Thanks.
uhhuh35 06-26-2007 05:17 PM
Uh-oh, here it comes. :D
LettersFromFlyoverCountry 06-26-2007 05:31 PM
Type in primer in the search box above. Trust me. Anythign that has EVER been uttered about primer, has already been uttered either here or on the RV List.
dsyvert 06-26-2007 05:38 PM
Primer
Ditch,
I went with a Sherwin Williams high solids epoxy primer for my empennage kit. The pros (IMHO) are 1) good moisture barrier, 2) good scratch resistance and 3) few people would argue it is a bad idea. Con: 1) it takes a lot of time and effort. This is how I prepped and applied.
1) Used Dawn dish soap and scrubbed each part with a scotch brite pad using distilled water from Wal-Mart in ~20 gallon bin using about 7 gallons.
2) Rise part with distilled water in ~20 gallon bin using ~ 7 gallons.
3) Pick up parts with nylon/plastic gloves to dry.
4) Dry at least over night.
Check weather for next day
At least 60F during spraying
At least 10 degrees difference between dew point and outside temp
5) Mix wash primer 484684 (w/other componets)
6) Get paint booth blowers, paint gun, etc ready.
7) Suit-up with respirator, Tyvek suit, etc.
8) Apply wash primer
9) Wait at about 1 hour while before epoxy primer (while doing steps 10 and 11)
10) Mix 483928 with other componets (after shaking)
11) Let stand for 20 minutes
12) Apply expoxy primer
I did the above in a 8'x8'x7' paint booth I made in my garage.
It is a pain, but I am glad I did it. I did one part with an zinc chromate rattle can in high humidity and did not like the result. It was/is very easy to scratch.
For the wings and fuselage I ordered the quick build which comes with the Sherwin Williams P60 G2 wash primer already applied. The wings are ~90% done except for part of the bottom skin and the fuselage is maybe 50% done. I consider the parts that have been done already on the QB are the "more" structural parts. The remaining parts that I will complete will be with a rattle can of SW 988, which you can get at the Sherwin Williams Automotive stores. ~$10 per can. I may put another sealer primer over with zinc chromate, but have not decided yet.
I would also recommend searching the folowing link:
http://www.paintcenter.org/pexpertqa1.cfm
Dave Syvertson
Sugar Land, TX
RV-10
Go Fighting Sioux :D
JohnR 06-26-2007 06:02 PM
Well at least maybe it will get us off the latest hot topic for a little while. :rolleyes:
Ditch, I started with AFS water based and ended up using an epoxy primer before I had gone to far. The epoxy was just easier to get the results I wanted and tough as nails. As mentioned above, do a search, you'll be able to read till your eyes are tired.
Good luck!
ditch 06-26-2007 07:28 PM
Wow, didn't know this was such a hot topic. I thought it would be as easy as mixing it up and spraying it on. Guess not. I think some of the extra work is a little over kill. I've painted on planes before, just repair work and I never did half the prep work and it turned out just fine. As long as there wasn't dirt or grease, it stuck. Anyway, I will read in the other forums and see what kind of arguing goes on at this site. Oh ya, do they prime just the ribs and internal structures or do they actually do the bottom of the skin as well? Is all that primer really necessary if you don't live or intend to fly along the coast with salty air? Just curious.
rv9aviator 06-26-2007 07:36 PM
I started with Sherwin Williams P-60 but have switched to Dupont Vari-Prime because it looks much nicer to me. It offers only limited protection but is better than raw aluminum. With most surfaces being alclad that was good enough for me. Unless you are on the coast I don't see the need in all that primng except for parts made from aluminum angle and other extruded parts that are not alclad. My 1957 Cessna 172 was in great shape with no primer. you can always spray the insides of the wings and fuselage with corrosion protectant too. Except maybe because of resale value from an added value prospective I really don't see the point in priming every single piece.
As always, just my opinion and maybe mine alone.
allbee 06-26-2007 08:36 PM
NONE, run her naked.
RScott 06-26-2007 10:15 PM
Here's something to think about: How are you going to prime when it's 25 degrees out? I understand it sometimes gets that cold in Fargo. Got a warm place you can vent? Waiting for warm weather so I could prime has put my project on hold several times.
FWIW, Sherwin Williams makes a rattle can primer you can use down to 40 deg. or less. NAPA's primer looks identical.
Several issuses back in the RVator they reported on a test where they left test pieces outside under a stairway for several months, maybe a year. One was naked, one had a wash primer, I believe, and the third I think had an epoxy primer. At the end of the test period, where it rains 40-50 inches a year and is humid from late October thru April, they found light corrosion on the unprotected piece, none on the others. You gonna leave your plane out in the weather?
ditch 06-27-2007 02:15 PM
Well I would rather not prime any of it to tell you the truth but I just assumed that's what everyone did and I don't want to be the only one out there that doesn't. I do have a heated garage that I can prime in during the winter. For peace of mind I think I will atleast use a rattle can to start. If it doesn't hole up, or gets to costly, I'll just quit the priming. So its perfectly ok not to prime anything hu? Any idea what percentage of planes aren't primed? I was taught in A&P school that everything you spray on weighs lbs. Keep the weight down.
