VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Tip: Minimalist Rudder Cable Tensioner (https://vansairforce.net/community/showthread.php?t=18959)
hevansrv7a 06-26-2007 02:15 PM
Here's how I put enough tension on the rudder cables to keep the rudder from flapping in the slightest breeze and it stays centered for when I'm pushing back into the hangar. I have seen more elaborate solutions and some of them also served as rudder trim, but this was very light, inexpensive and easy, since I already had the hole and bolt for holding the heater cable anyhow. It is easily adjusted, too. The termination of the bungee at the pedals is just a pair of cable ties on each side. This is providing enough tension for the intended purpose and so little that I'm unaware of it when I use the rudder.
picture here.
dan 06-26-2007 02:43 PM
Looks like you have a few items chafing in that area. The control cable, brake fluid lines, coax, etc. Don't want to spill brake fluid or short out your antenna... Just my 2 cents!
hevansrv7a 06-26-2007 03:07 PM
It's worth a look
I think the picture is fooling the eye, but I'll certainly take another look. Thanks for the heads up!
