VAF Forums
-   Alternative Engines (https://vansairforce.net/community/forumdisplay.php?f=22)
-   -   yowsa! I like it! (https://vansairforce.net/community/showthread.php?t=18846)
RAMPEYBOY 06-22-2007 03:42 PM
yowsa! I like it!
Check out this engine from GM!
http://www.crateenginedepot.com/LS-3...4-P1655C2.aspx
Basically a normal LS2, but with standard 4 barrel carb intake, and distributor!
Boyce
gmcjetpilot 06-22-2007 04:07 PM
Double yowsa!
Yea I saw it on Spike TV's Power Block "Muscle Car" Show. They stuffed one in an old Nova I recall. With out the FI and electronics, using the carb, Hot Rod guys are going to love it. Now are you thinking of putting this boat anchor in a RV? :rolleyes: Double yowsa! :D
Don't get me wrong, for a larger plane like a WWII scale replica (say a P-51) with a good reduction drive, usual problems of using water cooled engines in planes worked out, it would be a cool toy. There are reduction drives for them. However its size, weight and power are not in RV land, in my opinion.
If I still had my Camaro's, and wanted to spend some money on swapping the 1st Gen V8 out (which they still make) a LS2 would be awesome. However they make a monster 572:
http://www.crateenginedepot.com/ZZ57...793-P16C2.aspx
"There ain't no replacement for displacement" Now that is yowsa!
