FI Fuel Pressure "Spike"
All,
When I turn on my electric fuel pump I see a spike up to 45-50 psi for a couple seconds then it settles down to about 28 psi, which is what the engine driven fuel pump normaly runs at. Is this spike normal? I have a bendix rsa 5 type FI system on a lyc 360, vertical induction. I have the AFP high pressure electric fuel pump/filter set-up from Vans. Thanks Dave C RV-7 Flying!!!! |
Dave,
I don't think this is anything to be alarmed about. That high pressure pump is very powerful. I figured out that it puts out about 45GPH when I did a fuel flow test. I sometimes will see an initial spike when I am running the engine and turn on the fuel pump. The most I have seen was probably about 35 PSI. Mine runs consistently at 27psi otherwise. I have an IO-360 - 180hp with a Precision Silverhawk (i.e. Bendix RSA) servo and Vans FP gauge. Although, at altitude that pressure drops some and I see around 24-25 PSI at 10,000' -Rob |
| All times are GMT -6. The time now is 04:35 AM. |
