vividia va-400 borescope problem
5 Attachment(s)
I just got my new vividia va-400 borescope and unfortunately it got damaged in shipment. Does anyone know if these can be fixed? Trying to avoid mailing it back to the US if I can avoid it.
Attachment 1247 Attachment 1248 Attachment 1249 Attachment 1250 Attachment 1251 |
It's difficult to tell from the photos but is it just the protective sleeve that is damaged or does it not articulate properly?
If it is just the protective sleeve you should have received some spares in the box and directions on how to change them out. See the instructions. |
The sleeve is replaceable, but that item looks used to me. Was it to be new?
I don't like the S bend in the last pic. It only bends one way. The first time you push to bend, the lock engages, so read BEFORE pushing to bend so you know the unlock/hold |
And when you're out of new sleeve material, it is pretty much just a cut party balloon.
no workie
Seems like it took a heavy hit forcing the borescope down on the camera end, damaging the articulation part - possibly breaking a "tendon". Also, not clear why the rubber part looks a bit cooked - perhaps it is in fact used, or perhaps it rubbed back and forth on the styrofoam - not sure. I have not yet plugged it into anything to see if the camera even works. Mails into the ebay company I bought it from and Oasis Scientific. |
When working properly the camera end can turn around to look nearly 180 degrees from its at rest position.
If it cant do that it will be useless for inspecting valves in cylinders. |
I’d say damaged before shipment :( |
quick followup
I contacted both Vividia and the ebay seller, and was contacted by both that said they would be happy to send me the either the parts to fix it or send me a new one. I'll update once completed. Seems like pretty good support from these guys so far.
Bad news, I'm afraid. I damaged mine and the dude at Vividia said "non-repairable". Much more careful with the new one. Dan from Reno
My Vividia VA-400 borescope arrived brand-new through Aircraft Spruce. After 1 week and 40 pictures the clarity decrease dramatically. It was warrantied with a brand new scope. Glad I did.
| All times are GMT -6. The time now is 01:18 AM. |
