Summer time bugs...solutions???
I was just out in my garage with all the lights on putting together and breaking in my new compressor...and I have bugs and moths EVERYWHERE!!! It's driving me nuts!!
What are you doing about summer time bugs in your garage/shop? I need a solution to cut down on the population... HELP! :eek: |
Put a window air conditioner in the wall/window. I did, and was very happy I did. Both for comfort temperature wise and for bugs.
Bug zapper!
Use the shop vac.
Couple years ago, we had a tremendous number of flies. Every morning I would fire up the shop vac & suck up about 20 or so flies, many of them while they flew near the flourescent lights. Another RV builder had the same problem & found the same solution. |
Chad, I agree. We put in a small window air conditioner and just close things up if bugs or heat are a problem and keep banging away in comfort. No bugs and we can keep cool when it gets hot out. I just picked one up from Wal-Mart for about $200 and it works fine. Well worth the investment in my opinion.
They are a pair, Y'know. |
Best way to kill bugs here is to go fly, I usually kill several thousand on each flight. |
Bats!
Put in a bat cave in the back yard!
The window unit A/C is a great idea, and I've thought about it many times. I don't think I have the capacity on the garage circuit to add a window unit with all the lights on, and run the compressor. It's already as high as I'm comfortable with. I don't know the wiring from the garage to the box since I didn't build the house, and I'm not about to take a chance with overpowering the lines.
A bug zapper would never fly (pun intended) with my wife. :rolleyes: What else ya got? Oh, I do like the bat cave idea!! |
(Texans think everything is so big down here, but they've got nothin' to compare with BWCA bugs!) |
| All times are GMT -6. The time now is 01:45 PM. |
