Ideas on pitching a prop
I currently have my prop pitch set at 71.4 degrees, the Factory Van's setting, and I see about 4900 rpm static, and about 4975 on take off at 1000 ASL at full 1320 gross, at 75 kts, Vy, and a 650-700 fpm climb rate at 28C Thursday evening.
I still feel my prop is over pitched. I'd like to see around 5150 to 5175 at 75 kt's and closer to 900 fpm. I guess I am trying to see how much pitch needs to be taken out of the adjustable props to see my 5150 rpms, from the 71.4 degree setting that is there? Or should I call Sensenich for recommendations? How much rpms might you gain with a change in pitch from 71.4 degrees to a more shallow bite of air like 72.0 degrees, at climbing speeds of 75 kts 1000 feet above sea level? |
I don't have my aircraft logbooks with me so this is from memory. At my last annual condition inspection, I set it to 71.4. I was only getting about 4900 on the takeoff roll. I then set the pitch to either 71.9 or 72.0, I don't remember which and not I get between 5150 and 5200 on the takeoff roll.
ideas on pitching a prop
Sorry for the typo.
RPMs
I had my prop pitched shallow at first, was getting around 5100 RPM static and was too lazy to redo it.
My experience was that it was too easy to over-speed the engine in cruise If not paying attention, especially with the original throttle cable and springs that would creep forward on you. |
I think I am just going to leave it alone for now, get more samples on cooler and warmer days, and see if cooler days increase my rate of climb, and or climb out at 80 kts instead.
AP buddy also suggests we look inside the muffler for displaced or broken baffles, from the old Cessna days, but I think at 196 Hrs, kind of unlikely, but worth a look see inside. I haven't heard of any mufflers dying yet on RV-12's here. Engine just feels down on power compared to Bob's 2015, and he sees 5175 RPM at 75 kts climb out, same airport, with both of us in it. Carbs were synched by an AP from Lockwood, motor feels smooth, no vibrations until you get down to about 3800 -3900, very light and in a narrow range. Also cleaned, washed, air dried and re-oiled the air filters. Surprised how much dirt came out of them in the wash. Just trying to eliminate as many variables as possible. |
OK,
Repitched prop this morning with Van's tool. 2012 build RV-12 with Sesenich prop. Leveled plane to 0.0 on the Longeron with digital level. We inserted a 1/4" thick x 1/4" x 2" strip of black high density foam with adhesive on back, on the inside of the Van's prop pitch tool, which greatly stabilized the hold of the tool on the propeller blade, and made the line up of the black and white in the sight hole much, much more stable. it now keeps the little tang stop on the bottom side of the device pressed firmly against the bottom side of the propeller. We also add a piece of white tape with a straight line of ink at the shank of the prop, near the slot in the hub, as a witness index mark to see how much has been added or subtracted, pitch wise. Changed the pitch from 71.4 to 72.0, again, this is on MY plane. Temps were 25C elevation about 980 ft. Static rpms were 5020 rpms at full throttle 75 kt climb out showed about 4980 to 5000 rpm. Full throttle at 3500 ft, with a density altitude at about 5100 ft showing, straight and level, showed 5720 rpms. Plane is 775, 215# pilot and 12 gallons of fuel were in the tank. Fully dressed with wheel pants and fuselage, step , and wheel pant fairings. https://youtu.be/dCcQWGH88Jc This was the sound of the engine RPM's when I bought it in SC, note the very shallow take off angle from near sea level in SC. About 4800 rpm, with a cruise climb type of take off, very shallow. https://youtu.be/SMPIuDBEcdQ RAW data logs. https://flightaware.com/live/flight/.../KWHP/tracklog Flight. https://flightaware.com/live/flight/...721Z/KWHP/KWHP Will take a month or more of lessons with it this way, probably try to solo and then see how it does with just me in it. Then possibly re pitch, as necessary, as the climb rate at 75 kts still feels a bit anemic. Want to wait a bit for some cooler weather and lower temperatures to test it out, instead of the heat and hmidity of July and August. Control wise, it's a very steady, stable and great flying plane. Just feels, still, a little anemic on the climb rates in FPM and in RPM's. Got to get over that torque hump and into the HP portion of the power band. 5150 to 5175 seems to be the sweet spot with full throttle climbs at 75 kts. |
Not that this helps or maybe it does.
2018 Rv12. my Numbers. 71.4 pitch,2 people ,full tank,i get 900 FPM at 3000 ft elev in 75 degree weather..by myself I can maintain 1150-1200 FPM with 10 Gallons of fuel.5080 static,around 5150 on climb @75knts. I have wheel pants,and all usual legal speed mods. Tried a 72 pitch and had too much RPM,so went back to 71.4 |
Either that, or I somehow have a very anemic 912ULS Rotax, motor. How the prop behaves at cruise, at elevations above 7500 ft, once you get up there, is great. I won't be the least bit surprised if the Van's measuring device ends up needing 72.6 to 73.0 degrees to get the engine making the rpm's and climb rate I want at 75 kt's Vy on take off from 980 ft. Plane should make over 900 ft minute with my instructor only weighing 120 # and well under gross with near a half tank of fuel. I guess I am looking for input from people with early serial number builds or that bought the prop before 2013 or 2014 or so. |
I have a 2010 RV-12, SN 120230 so the same prop as you. I've played with prop pitch quite a bit, from climb-like-a-banshee to cruise-like-a-rocket. Don't be afraid to experiment, but there is no single setting that will make you happy with both climb and cruise. That's the nature of a fixed pitch prop.
There are *many* other threads on this subject, I suggest searching for and reading them. Roger Lee has rules of thumb for propping a Rotax 912 that lots of people seem to follow: https://vansairforce.com/community/s...17&postcount=3 |
The angle settings quoted are misleading because when you get close to the sweet spot you get down to tenths of a degree adjustment. It is easy to miss “level” by tenths of a degree. I adjust mine by tenths of an inch from as found and don’t worry about the absolute value of the blade angle. Big thing is to match the left and right blade angle each adjustment.
| All times are GMT -6. The time now is 04:10 AM. |
