How To Prevent Flutter And Other Aeroelastic Modes
Ran across this article in Aviation Week. May require free registration/subscription to see. Very interesting on flutter.
https://aviationweek.com/business-av...oelastic-modes Also here are two embedded videos from the article on flutter Part 1 https://www.youtube.com/watch?v=rb3JHY_-ia4 Part 2 https://www.youtube.com/watch?v=jW8I2hX4GSs |
Interesting article and the Youtube links. There was a recent post about a F1 Rocket that lost most of the horizontal stabilizer but the pilot managed to land it safely. Scary stuff.
The F1 Rocket that recently had the tail damage was above VNE however the failure appears to have been caused by a rapid G onset starting from a negative G value to above 8 G?s with a high onset rate. It does not appear to be flutter.
I have had a prop/engine whirl mode with my 7, IO360 M1B engine w/Hartzell composite prop. The spinner moves 1/4" off center. It has occurred at low rpm after a gentle bounce on the runway. Has anyone else had this occur in an RV?
Gust Loading
Below is a link to a pitch I put together a few years ago. It describes different aeroelastic phenomena, including buffet, divergence, control reversal, control surface buzz, forced vibration, flutter, aeroservoelasticity; and discusses basic principles of flutter prevention.
"An Introduction to Airplane Flutter": https://drive.google.com/file/d/18nb...ew?usp=sharingEnjoy! |
Nice briefing Carl! This thread should be a sticky just so guys can find that easier.
Brian |
Carl,
The presentation, IMHO, is beyond excellent. I benefited from 15+ years of mentoring by John Thorp. After his passing I contacted Martin Holman (noted flutter expert) to reinforce John's position as various "modifications" were being explored by T-18 builders that my personal exposure led me to conclude they were not consistent with John's position. The push-back to my request to "think it over" was interpreted by many as "You have to do it my way" - even if I specifically stated otherwise. This presentation is the most "together" survey I've come across and I thank you for bringing together the concepts and teaching me what (except in limited circles) usually isn't taught! Thanks again! |
| All times are GMT -6. The time now is 02:48 AM. |
