anyone know where I can get a steel plate behind prop?
I'm putting our 6 back into phase 1 soon to change our GW. My problem of fwd CG is exacerbated by light weight engine and prop. I have heard of a steel plate idea some have used in the past that is drilled for the prop bolt pattern to help add some Wt to the front of the airplane.
Any ideas on where I could get one? Thanks in advance. |
Check with Saber,
He does a lot of experimental prop plates and extensions. Nice guy to work with. |
As a bonus, they are in Grandbury. You will have to replace the prop bolts as well, he sells a whole kit with everything you need. http://www.sabermfg.com/ |
Good deal. Thanks everyone. Out of curiosity, do you remember how much the plate changed your CG?
I have one
PM me and I can send you some pictures and talk about it. |
If you can track down a Landoll Harmonic Balancer that would do the trick nicely. Had one on my -6 and loved it. Unfortunately they are becoming quite scarce.
15 lb crush plate moved my CG about 2 inches fwd on a RV 9 with fixed pitch and composite prop. I also purchased a prop extension and added 1/2 inch From Sam along with the crush plate. Made all the difference with min fuel on board.
Needed for all the testing i was doing with the props. No longer testing. |
Another vote here for a Landol dynamic balancer. I have one on my RV-3B and it runs turbine smooth. Put the added weight to work for you.
Do you guys know the weight and cost of the balancer? I'm trying to run some Wt and Bal scenarios on how much weight up front will have an impact on my envelope.
Thx |
| All times are GMT -6. The time now is 04:53 AM. |
