Confused trying to find Lycoming manuals
Hello, I am deeply confused on why it is so difficult to find maintenance manuals for my IO-360-M1B. The engine didn't come with manuals (which is mega annoying considering the cost of it). Can someone who has been around the block a time or two tell me what I should/ shouldn't expect to find here. Do I simply go off of a similar model?
I am mainly trying to find torque specs. I have found an operators manual here but that doesn't have torque specs. Thanks |
Lycoming doesn't make a maintenance manual for your engine. They published the Lycoming Direct Drive Overhaul Manual which includes your engine. There's also SSP 1776 that has the metrics and there's also a parts catalog. Lycoming does publish an owner's manual for your engine. But, truth be told - you should really know what you're doing when you go into your engine - or have someone there to guide you. There's nothing worse than killing your family, friend's son or people on the ground because you really didn't know what you were doing when you tore into your engine like it was for your lawn mower. Then there's AD, SB, MSBs for your engine then there's manuals for your accessories just as complex as your engine. Some you have to pay for, some you can find for free. You just have to search. Oh, yea - they publish updates for everything too so you have to be careful as to what version you get. Also there's AC 43.13-1b and the whole AC series. You can also search 14 CFR for stuff that covers your engine too like how to do a compression check, clean plugs, inspect stuff and so forth. Don't worry - some smart engineer with years of experience and education, a PE license, insurance, peer review process, etc etc etc wrote the stuff that's FAA approved or accepted - if it's made there's PMA approval, STC's too - don't forget that stuff.
But truth be told - the aviation industry is filled with people too lazy to read, failed to pay attention to their instructors, barely passed their classes, have no interest in aviation, think they're smarter than they actually are, will tell you "that doesn't matter" when you tell them they're not doing it as the book instructs (because they never read the book), they barely made it out of high school where they took shop and as many P.E.s as they could. They're poor, foolish, have low IQ's, and are just plain lazy. So maybe you're better off doing things yourself. Good Luck |
Also searching...
Jereme,
I am in the same position as you and have also been searching. The -M1B is the same as the -M1A except that it has a rear prop governor and an impulse magneto. Lycoming has an -M1A Operation and Installation Manual that I found online : https://www.lycoming.com/content/ope...0-M1A-60297-36 It does not have installation torques that you were looking for, but it does have basic schematics, specifications and performance curves for the power plant that would be included in a compiled POH. I am building an RV-7 just a bit behind your progress and I have enjoyed and learned a lot following your build progress here online - thanks for documenting your build and sharing your enthusiasm! I am also following this thread with interest. - Alex - |
I use The Lycoming Direct Drive Overhaul Manual. It has a whole section in the back with torque values used through out the engine. Your prop manual should have values with your particular prop model. AC43 has charts for torque values for general AN hardware. Vans manuals also show torque values for common hardware used in the airframe.
I also still need to find the values for the governor. I am glad my build log has helped you out! I really like it when someone gets benefit from me posting all those! |
Torque Table
If you can't find the torque for specific hardware, you can follow the chart in AC 43.13.
Jereme----send a PM to Mahlon---
Tom |
Are you looking for the Lycoming Service Table of Limits and Torque Value Recommendations? https://www.lycoming.com/sites/defau...20Complete.pdf |
| All times are GMT -6. The time now is 06:56 AM. |
