VAF Forums
-   -   Tire/wheel balance (https://vansairforce.net/community/showthread.php?t=182903)
cderk 05-27-2020 11:31 AM
Tire/wheel balance
Wondering how many folks have actually balanced their wheels? Like many I have a shimmy from my mains around 30-35 kts when rolling out.
I bought a wheel balancer and the wheels needed 1.75oz on one and about 2oz on the other. Virtually in the same spot too - near the red dot where you?re supposed to put the valve stem.
I took transition training in the factory -10 which also had a shimmy. The instructor told Me that the wheel needed to be balanced.
I?ve got the stock grove wheels and tires that Van?s sells as per of the kit.
I have to imagine that if it is indeed off by this much, this could be the source of the vibration.
Thoughts?
Gash 05-27-2020 12:22 PM
How are your tires after you did the balance? Shimmy gone?
I bought a Harbor Freight wheel balancer to use next time I swap out tires. I'm hoping it's worth the effort...can't hurt I suppose.
cderk 05-27-2020 12:57 PM
Karl - havent tried it yet. I bought the bubble balancer from Harbor Freight... the other one wont work... I tried. its for wheels with a less than 1.5? hub.
I?m hoping to get things put back together and fly in the next 2 days. I used proseal to attach the weights. 4 inboard and 4 outboard.
jrs14855 05-27-2020 01:09 PM
Balance
motorcycle shops have stick on balance weights in 1/4 oz increments. They can easily be cut into smaller pieces.
Gash 05-27-2020 01:46 PM
Hmmm...didn't think about the hub size. I'll probably just fabricate my own hub sleeve to make it fit.
Jetmart 05-27-2020 02:24 PM
Anyone use tire balance beads?
https://www.youtube.com/watch?v=w8b6eqde_5A
David Paule 05-27-2020 02:41 PM
So how do you get the beads into the tube?
Dave
lr172 05-27-2020 02:49 PM
I used them on the 6. I have had good success using them on motorcycle tires. When I swapped tubes duing a CI, I chose not to reinstall them and still had no shimmy, so can't say positively if they work in our RVs.
Larry
lr172 05-27-2020 02:50 PM
Dave
Pull the schrader valve out and insert beads via a vynal tube pushed over the threaded portion of hte stem. Most bead kits come with a small bottle and tube for installation.
Larry
Pilot135pd 05-27-2020 03:15 PM
Larry
Won't the beads eat up the innertube? That pressure on somew points on the the innertube has to do something to it.
