VAF Forums
-   Southeast (https://vansairforce.net/community/forumdisplay.php?f=65)
-   -   Tail wheel Endorsement Needed-Insurance advice (https://vansairforce.net/community/showthread.php?t=182668)
LR60 05-20-2020 05:08 AM
Looking for any advice on where to get a tail wheel endorsement around the piedmont triad aera in NC.
Since I have zero time in tail wheel and type, the insurance quote stated I would also need 25 hours total tailwheel and a CFI checkout in type prior to any coverage. Is this the norm for zero time TW pilots?
I plan to do the RV 14 with Mike to take care of checkout but I first need to start building up TW time.
Northernliving 05-20-2020 05:27 AM
Is it the norm? I would think so, but I never went through the transition. Can't help you with location, but I believe the transition would take 5-10 hours depending on your flying experience. Then rent something like a Citabria or Decathlon to build some time, experience and confidence. You should be all set for your 14 transition training with Mike by then.
N941WR 05-20-2020 06:13 AM
There are two places around Charlotte, but I don't know about the Triad area.
There a number of tailwheel RV's in that area, so someone must be instructing with a TW aircraft.
Yes, it typically takes around 10 hours to get your TW endorsement.
Good luck!
sailvi767 05-20-2020 06:27 AM
I had no such requirement when I purchased a RV6 with zero tailwheel time. They only required that I receive the endorsement.
fixnflyguy 05-20-2020 07:13 AM
Mark,
Mikey Mathews at Lake Norman does the TW endorsments and has a bunch of RV time. He is very good, and well recommended. A friend of mine who just bought an RV-4 that I ferried back to NC from Fla. He went down to Jan Bussel in Okeechobee for a long weekend and got his TW endorsment there, as well as RV training. Jan has 2 RV-6's. Sugar Valley over near me in Mocksville/Advance area had a Carbon Cub they were renting, but Im not sure if they are still doing that.The fact that you are going to have a zero hour new RV-14 in phase one is your biggest hurdle, and you may consider a seasoned RV pilot as 2nd crew member which is now allowed for your first part of phase one.Look forward to coming a and chat about your project..dang KC-10's have me busy !
zmatt 05-20-2020 07:18 AM
10 hours? I would say that is excessive unless there are some issues going on with the training.
Mark,
If you need 25 hours it might help to find a place that will rent you the TW airplane once you have your endorsement. I know a lot of the schools only fly them dual.
rocketman1988 05-20-2020 07:38 AM
Why?
Why would you think 10 hours is excessive?
If that is what it takes, that is what it takes...
It has been my experience that folks who don't think they need the instruction, actually take longer to become proficient...
zmatt 05-20-2020 07:53 AM
Because its like getting your PPL in 2-3 months but it took 100+ hours to complete. The CFI is probably wasting your time flying stuff that is not helping the student become proficient in the required flying.
Even if the student is rusty you should be able to knock that off in a flight or two. But yes you are right there is always that student that needs extra flying. I still feel that 10 hours of dual is excessive. Now if you are saying 4 hours of that are ground instruction then that is more realistic.
Remember there are student pilots soloing tail wheel airplanes with not many more hours than that.
Cheers.
rocketman1988 05-20-2020 09:03 AM
...and
...and there are B-777 Captains with 30,000 hours that take substantially more than 10 hours...what is your point?
The instructor will provide the endorsement when he is confident in the student's ability...and putting an arbitrary number on that is ridiculous...
I know of several places tailwheel instruction is given and they pretty much say 10-15 hours. If you do it in less, great but the problem is if you say 5 and the student gets to 8, they begin to get frustrated.
It is very difficult to learn anything once frustration sets in...
N941WR 05-20-2020 09:14 AM
Mark,
What part of "typically" don't you understand?
Some take more, others less. In talking with friends who have gotten their TW endorsement that seems to be a good number.
Most get really frustrated around the four to six hour mark and then it just "clicks". The rest of the time the instructor will spend making sure they have it and then focusing on crosswind landings, wheel landings, three point landings, etc.
Also, the reason they fly them with an instructor only is because even with 10 hours of instruction, the insurance companies won't trust their insured aircraft with newly endorsed TW pilots.
