| Pilot135pd |
05-18-2020 01:31 PM |
When I decided to install the Dynon AOA heated pitot tube in my 10 year old plane the thing that had me the most preoccupied was threading those wires through the wing because I had read on the forum so many horror stories.
Again, I'm not a RV builder but with the help of a twice around RV-4 builder (thanks Arlie) we came up with a simple solution that took a little over an hour total.
Drill through the ribs, install plastic Lowe's snap bushings, then add a PEX tube (which is smooth inside) and done! I put a little bit of Goop sealer where the PEX came into the fuse to keep it from moving and the wires went through easily. We first thought about using a PVC pipe but then realized that PEX weighs less than PVC.
