VAF Forums
-   RV-7/7A (https://vansairforce.net/community/forumdisplay.php?f=7)
-   -   Smoking Wing Tip Attachment Hinges (https://vansairforce.net/community/showthread.php?t=182389)
mcgaughy 05-12-2020 06:31 PM
I need to decide soon whether to attach my wing tips with traditional screws or hinges. I was told today that the hinges wear with age and get loose / start smoking. Has anyone had this experience on their tips mounted with hinges?
Ellis. RV7a Tip-up.
noelf 05-12-2020 07:14 PM
No issues here with the hinge attach method, but then I don't fly that much any more. I have two different sets of wing tips and use the hinge method to rapidly change from one set to the other. I have never had any "smoking" issues, not with the rivets and not with the hinge segments.
If you are concerned, what about all the RV's that attach the cowling segments with hinges and pins?
Richard Connell 05-12-2020 08:44 PM
Ellis. RV7a Tip-up.
Sounds implausible to me.
10+y on my wingtip hinges. No problem.
It?s an awesome mod. Only downside is marginal weight gain and probably a days work.
Raymo 05-13-2020 07:53 AM
You can always bond them with Proseal + rivets to avoid the issue but probably not necessary.
bullojm1 05-13-2020 07:58 AM
+1 for this. I have 700 hours in 10 years on my wingtip hinges and they look as good as they did day one. Would make this mod again in a heartbeat.
MS19087 05-13-2020 08:26 AM
Just finished mine on my RV-14
They came out great - really not a lot more effort than the screws i did on my 9.
Mike's guidance was very helpful . . .
Jetmart 05-13-2020 10:17 AM
Is there a good resource to find out how to install the hinges properly?
MS19087 05-13-2020 10:33 AM
Search
Do a search . . . bullojm1 did a nice write up.
NavyS3BNFO 05-13-2020 10:47 AM
Here's the link to Mike's great write-up:
http://rvplane.com/pdf/WingtipHinges.pdf
jibby212 05-13-2020 11:06 AM
I just installed my wingtips using the hinge method. I found it difficult to tape the tips in place until I placed a few inflated balloons in the tips which expanded the tips so they fit the wing snuggly. I also ripped a V groove in a 2' long 2X4 and set it over the trailing edge to keep it aligned while fitting and drilling. It made the process pretty easy.
