| rv3pilot |
05-23-2020 10:03 PM |
Originally Posted by DTARM1
(Post 1432971)
You actually fly an airplane that rolls 50 degrees per second if you don't put pressure on the stick to counteract the roll?
1) Aileron control surfaces or trim tab are/is out of wack (use a digital protractor)
2) Aileron cable tensions are out of wack (Use a cable tensionmeter)
3) You've got a warped wing (use the digital protractor)
4) Your V-stab / rudder is causing the roll (use a tape measure)
5) You've got asymmetrical flaps (digital protractor)
Geometry is cheap and easy if you're smart enough to know how to apply it.
Regardless - your airplane is not airworthy if it rolls 50 deg/sec without you making it do that.
I would ground your airplane
Mine did the same, but only at 180 mph. At landing speeds it was not noticeable. A very small tweak on the trim tab fixed the problem. The tweak was so small (using my fingers when getting gas), you can't really see a change but boy did it fix the roll problem. And it as a pretty hard roll. No affects on speed or yaw. Ball still centered at cruise.
