CDI
I have two CDI torque wrenches.
One 1/4 and one 3/8. Covers everything. I understand CDI makes Snap On torque wrenches. Either way they are very nice. |
+1 for CDI
I bought one of these CDI wrenches from Avery Tools years ago when I started my project. Cleaveland sells them now -
https://www.cleavelandtool.com/produ...18378249044030 It's not the cheapest torque wrench you'll find, but it's an excellent US-made tool. HTH, YMMV... Dave |
It doesn?t matter....
You take them both to work and cal them both! Seriously, you do the mass- distance cal or send them out. Yes, it’s happened. It’s still better to know something might be whacked, right? Admittedly, I only do this after long periods of not using them
The main advantage is the head is a lot smaller than a click wrench that it can fit where the click won't. And they never need calibration. |
I had no idea that was even possible. Just shows you learn something new every day. (I wish I could buy a split beam torque wrench with a ratchet head! I've never seen such a thing.) |
This ..... https://www.harborfreight.com/12-in-...ter-63917.html is very accurate and consistent that I use it to check all of my torque wrenches.
That's the one to own! Electronic wrenches are accurate and repeatable. Your beam type wrenches accuracy is 10-20%, HF is 1-2%. So which one would you use?
I guess for occasional use one could hook up an external battery. Finn |
| All times are GMT -6. The time now is 03:07 PM. |
