Anyone using GTR 200B for intercom?
I?m curious if anyone is using the intercom function available in the GTR 200/200B and how it compares to a stand alone intercom.
I?m redoing the panel in my RV8 and am installing the 200B and considering not wiring in a separate intercom, if it really works as good as advertised. Any comments from you guys who have done this would be appreciated. Thanks |
Yes, two of them. They work great,
Great 👍
Wonderful radio, great intercom👍👍👍
We just replaced the SL 40 and Flightcom intercom in ours with a GTR 200B. Much, much better. The 3D audio features are really nice. I?m able to adjust the volume of the aux inputs (GPS and EFIS) from the radio. And I flew it without having to touch the squelch once, which I?m pretty sure was the first time that?s ever happened. Not to mention the ability to use BT for tunes in the air and phone calls on the ground.
Intercom works great. Really like that it has a number of audio inputs.
2nd Comm
I have a SL-30 with the standard belly mount comm antenna (RV-7), if I added the 200B as a 2nd comm/intercom where would the second antenna typically be mounted?
Figs |
Thanks for the replies.
Looking forward to using it!! |
200b
I have it installed as part of my big 2020 avionics upgrade. Heard nothing but great reports, so I bought one. Should be wired up and tested in next week.
With blue tooth phone calls, music in...sounds great. Good luck. |
I'm putting a full Garmin panel in with the GTR200B as the sole comm...no audio panel and the 200B will serve as the intercom. Stein say's there are enough inputs to handle the inputs from the GNX375 for the alerts.
Keep in mind the GTR 200B has a fantastic stereo intercom, but it is not a switching audio panel. It is basically like having a one great comm radio and a top end stand-alone intercom like a PSE PM 3000 built together into one. And like the PM3000 its intercom doesn't switch sources. That means if you are going to have more than one comm you pretty much need a separate audio panel and skip the GTR 200B's internal intercom. Jim |
| All times are GMT -6. The time now is 06:14 AM. |
