VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Best injuries while building (https://vansairforce.net/community/showthread.php?t=181590)
AlpineYoda 04-19-2020 10:49 PM
Spent some time at urgent care today. Thankfully, it was a covid-free urgent care.
I was match drilling holes in the tail cone skin of my RV-10 build with my son today. Did about 300 holes with a high speed pneumatic drill through the skin into some stiffening bars. I had to hold the pieces in place with a hand on the inside, while I drilled from the outside. My son then dropped Clecos into each hole to keep everything aligned.
For the first 300 holes, I thought about the location of my inside hand every single time before drilling. Around hole 301, my mind slipped a little. The pieces kept moving and I had to try hard to hold it all together. I doubled the tank regulator pressure to get a faster drill speed to avoid the bit ?walking? along the metal. I pressed down hard, went through both pieces of metal like warm butter, and then straight through my index finger that was holding the pieces in place on the inside. Clean entry and exit wounds on either side.
It bled like nothing I?ve seen before from a #40 size hole, but I had some crazy glue in the hangar and was able to stop the flow. X-rays at the hospital showed that I missed the bone, missed the ligaments, and left minimal aluminum inside my finger. I might have some nerve damage, and I got a new tetanus shot, but it seems like I may have been really, really lucky to avoid major damage. I will post a photo on my EAA blog (below, since I cannot figure out how to post here) tomorrow.
I can?t be the only one to hurt themselves building. Any good stories out there?
BobTurner 04-19-2020 11:27 PM
Welcome to the club. Hurts like he**, doesn?t it? I went well into my finger despite wearing work gloves. And I?m not the first.
AlpineYoda 04-19-2020 11:35 PM
Yeah. And Tylenol and a couple of martinis aren?t helping at all.
JDeanda 04-19-2020 11:50 PM
Aarrgghh. I think you'd get a shorter list of mechanics who HAVEN'T drilled thru a finger. I think I've only done it once, and then not all the way thru. I've been bitten by band saws twice, fairly serious the second time but I'm OK. I stood up fast while working on a Pitts S2A once and banged my head on the trailing edge of a metal Hartzell aerobatic propeller blade. Went right to my knees and stayed there for a minute or two. Yeah that one really hurt. I'm not looking forward to more stories along this thread, it could get pretty gruesome if folks don't use a bit of restraint.
N941WR 04-20-2020 01:21 AM
Been there, done that. Right thru the mail on my ring finger. Not to worry, the nerve will grow back in a couple of years.
This is why I don't walk in my shop without putting on safety glasses. Stuff happens. (I have had more than one cleco come out if the pliers and hit my glasses.)
Hornet2008 04-20-2020 02:13 AM
Your right index finger will survive a trip through the pneumatic squeezer. Whilst riveting tank baffles, stopped to wipe wet pro seal off the squeezer dies. Rolled the squeezer on the bench for better access and BANG. Hurt like nothing else, bled all over but wrapped it up with blue masking tape to stop bleeding and continued riveting. Lost the nail and feeling for some time but all good now about 5 years later.
daveyator 04-20-2020 02:54 AM
Probably not in the same league, but those cleco clamps can produce high pain levels and nasty blood blisters on those days when your not right on your game. Trust me.
An unplanned hole in your finger though....ouch. My sympathy.
The pain will subside with time, but I'm sure you'll still have the memory.:D
Cheers, DaveH
Richard Connell 04-20-2020 03:55 AM
You only have to skin your shin on a low lying step weldment once before you wrap them in foam!
I?ve drilled a hole in myself too...:-(
Peter Costick 04-20-2020 04:34 AM
I did a similar thing to the OP, but with me it was through the wing spar into the palm of my hand. It didnt go right through but stuck in my hand. I was kinda stuck until I realised it was a reversing drill.
Not too much blood but there was some other stuff kinda hangng out. Pushed it back in, added a bandaid and continued working.
RViator60 04-20-2020 05:06 AM
I can't say that I've had any major injuries...yet, other than scratches and small cuts. However, I can share a story I heard about a guy getting his finger pinched by a pneumatic squeezer, resulting in bone damage and ultimately loosing the digit. Since then, I have a lot of respect for the squeezer. You were lucky with your injury, but I imagine it must hurt like ****.
