VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   Replacing Stripped Nutplates (https://vansairforce.net/community/showthread.php?t=181391)
avrojockey 04-14-2020 10:43 AM
So it seams an overzealous individual with an impact driver took out some nut plates in my seat pans.
I want to replace any stripped nutplates but not sure I need to invest in a squeezer.
I saw some recommendations using "oops rivet" sized blind rivets...are there any other recommendations?
Tim
Bavafa 04-14-2020 10:54 AM
An inexpensive squeezer to have is a good thing and I might even consider it an essential tool for an RV owner. If that is not a possibility, smaller pull rivets are available and acceptable.
Jpm757 04-14-2020 11:02 AM
I have used MK319-BS rivets with success.
gasman 04-14-2020 11:10 AM
You can use an A rivet in place of an AD. The A is softer and easy to set with no effect on the nutplate or it's use. You can set them with with altered ( smooth down the grip teeth or cover with a piece of aluminum) pair of vise grips. Or you can use these.... https://www.homedepot.com/p/KNIPEX-1...-SBA/206162134
The vise grips are a lot cheaper.
PhatRV 04-14-2020 12:00 PM
+1 on the mk319 rivet. Drill out the old alumninum rivet and install the new nutplate using the pull rivets
xblueh2o 04-14-2020 12:05 PM
Originally Posted by gasman (Post 1422302)
+1 vote for the Nipex parallel jaw pliers. I use these to squeeze both A and AD -3 rivets often.
HAL Pilot 04-14-2020 12:10 PM
Ask your local EAA chapter for a loaner tool??
pa38112 04-14-2020 01:19 PM
This is a great squeezer for $135. You will use it extensively owning and maintaining your plane. It is all you need since you are not building : https://www.aircraftspruce.com/catal...clickkey=26925
fl-mike 04-14-2020 01:26 PM
CCR264SS3-3 3/32 CS blind rivets
I have a small bag I picked up from Airparts at SnF. They come in handy once in a while.
https://www.airpartsinc.com/712_CHERRY_RIVET_CCR.htm
Sam Buchanan 04-14-2020 02:14 PM
I built my RV-6 with that squeezer......highly recommended as a reasonably-priced addition to every non-builder RVer's toolbox..
