3/4 turn method for oil filters
What's the 3/4 turn method for oil filter torque?
I assume it is: - use a marker to label 90deg / 180 deg / 270 deg / 360 locations (and maybe in between) - after screwing on the oil filter, from the moment the gasket touches the body, using the markings as reference, ensure it's been turned an additional 270 degrees? - safety wire. |
Spin on the filter 'til the gasket touches then turn 3/4 turn more. Really doesn't matter if it is 269 or 271 degrees, don't get anal.
Oil Filter
You can?t go wrong with the official guidance, 18 to 20 ft lbs is the torque for the Champion brand. They also specify Dow Corning DC-4 as a lubricant on the rubber gasket before install. The 3/4 turn method with some engine oil on the gasket works well enough if you know what tight enough, but not too tight feels like.
Don Broussard RV9 Rebuild in Progress 57 Pacer |
The 3/4 is bush style... better follow the manufacturer?s instructions, usually a specified torque.
Also beware that some, Tempest as an example, are installed dry no oil. |
If you don't have a fancy torque wrench, "Bush Style" works pretty good, and has done so for a few decades. In fact, some filters have the "3/4 turn" instructions included. Could that be construed as "Manufacturer's Data?"
Some things require more precision than others. Just my Dos Centavos............. |
Torque wrench
Couldn't agree more that a torque wrench, or two or three torque wrenches, are needed for construction and maintenance of aircraft.
However, most standard torque wrenches and their required sockets or crowfoot extensions don't fit easily on the oil filters installed on most RV aircraft. Hence the existence of "fancy" purpose-built oil filter torque wrenches. I borrowed a friend's oil filter torque wrench, and at the same time, I marked the filter for a 3/4 turn. Result was withing a few degrees of the 270 degrees required. Again, sometimes precision is required. Sometimes it's not. I would submit that oil filter torque is not a close-tolerance issue. YMMV, as always. |
How do you put a torque wrench on a WIX oil filter?
Just did the oil filter change gig yesterday. Champion. Hitting resistance and then going 3/4 turn is not enough torque IMHO. I torqued to that standard, then torqued further to 18 ft/lbs and was really surprised to see how much more was required to get to spec.
Exactly!!
I will admit to having some troublems when getting the filters to come loose - that 3/4 turn really does the trick, but sometimes you will need a helpful tool to get ?em off. Filter wrenches might be required for removal - 3/4 turn is all that is needed for the ON process. |
Morale of the story; "Never say never," especially in an airplane. :cool: |
Interestingly Rotax uses the 3/4 turn method and there is no safety wire. I make a point to check the mark before each flight. ;)
Since, I have owned three Toyotas and all +/-200K miles and never visited the repair shop, only oil/brake/tire and windshield wipers. |
The filter was exactly above the exhaust. You could not possibly change it without burning yourself. My procedure was to have the oil changed, let the car sit overnight in the garage and then, when it had cooled down, loosen and reseat the filter. |
APPROVED!!
My RV taxi
After the dealer nearly stripped out the drain plug on my taxi I use to pick up RV parts, i dont let monkeys work on my cars anymore.
How do you keep the hose clamp from loosening? :rolleyes: |
Oil Filter Safety Wire
I've posted this before, but what the heck:
It's interesting to note that Robinson Helicopter does not require the safety wiring of the Lycoming engine oil filter per their Service Letter shown below: https://robinsonheli.com/wp-content/...2/r44_sl45.pdf SUBJECT: Deleted Safety Wire "BACKGROUND: Safety wire and safety wire provisions have been deleted from various installations and parts. Deleting safety wire reduces maintenance cost and decreases the potential for safety wire-related FOD. This letter provides guidance for installing parts with or without safety wire provisions." If a helicopter manufacturer doesn't think it's necessary ... (For transparency, my oil filter is safety wired.) |
No. I've never had a filter loosen or a clamp. But if you keep adding 'safety' where does it stop............... Clamp too loose, doesn't do anything. Too tight, you might put a hole in the filter. |
Actually, the 3/4 turn method is far more accurate than a torque setting (not that it is super critical in this application). 3/4 turn will always compress the gasket the pre-determined amount. The filters have 16 threads per inch, so 16 turns will produce 1" of travel. Therefore one turn will produce 1/16" of travel. 3/4 turn will compress the gasket 0.046875". You cant say the same for a torque setting. - Prove it to yourself by doing both. Mark the filter and then set it with a torque wrench. Measure the rotation you achieved. Also use a inside caliper to measure the gap between the filter face and the filter housing face. Do this over a few oil changes.
For high precision "Torque" settings the angular method is always the preferred method. A torque wrench is used to ensure all parts are pulled-in together and then a angular rotation is set using a torque angle gauge: https://www.amazon.com/OTC-4554-Driv...780774&sr=8-12 |
All cannister oil filters are tested(developed) to a standard test procedure. Today it may be some ISO test, but the 3/4 turn was based on the SAE hydraulic pulse test to ensure it would not fail internally, or come loose. Included is a 1/2 turn and even a 1/4 turn test to be sure it is not on the edge of acceptability. The pulses and pressures are much higher and any engine produces, diesel or gasoline.
There has to be a historical reason for safety wire, but not sure why torque is involved, it was not part of the past test procedure. If a Toyota filter "came loose" it was never tight. |
^^^ Exactly right ^^^ |
The Rav filter failed because it was not tight. |
And since all the filters i've seen say 3/4 turn after bottoming on the rubber, there's no real need for a torque wrench. I've never seen a safety wire on an oil filter that was under any tension when it came time to remove it, either, and yet I still safety it because "it's always been done that way." Unfortunately the closest safety wire point on my twice-overhauled-and-due-for-a-third Lycoming finally wore to the point where it broke off the last time I did an oil change, so I had to safety the filter to another nearby hard point. |
![]() I actually had to use a BIG hammer and chisel to pound on the circumference of the base to break it lose. I will NEVER torque to manufacturer's specs agaion. Now I use the 3/4 turn method with no problems. A couple flights ago I used the hand tight plus 1/2 turn method and I'm still alive to tell about it. |
Erich |
3/4 turn always works. I have that ‘special’ oil filter wrench. It torques the can tighter than 3/4, every time. I don’t use it. 3/4 turn doesn’t over torque the filter, and doesn’t leak. That’s the measure - doesn’t leak. Second measure - you can get it off during the next oil filter change. This is a relatively liberal spec, dealing with a compressible gasket subject to relatively low pressure - usually less than 100psi. With a fairly coarse thread, safety wire will hold the torque pretty close, even if you don’t get the safety wire installed really tightly.
| All times are GMT -6. The time now is 11:24 AM. |
