VAF Forums
-   -   Need a filter for my new-to-me 550 gallon fuel tank (https://vansairforce.net/community/showthread.php?t=181237)
Pilot135pd 04-09-2020 04:10 PM
I just bought a 550 gallon fuel tank and, even though I use a filter when I pour from my 5 gallon tanks, now with the big tank I'm looking for something to permanently install either inline (in the 1" hose) or at the 3/4" adapter coming out of the tank.
Things I'd prefer but not completely deal breakers:
- with a clear container so I can see the debris as it's trapped
- local purchase if possible so I can go get it tomorrow (if not I'll order it)
- reusable so I can clean the element instead of having to buy new disposable cartridges.
rag 04-09-2020 04:41 PM
I use Goldenrod filters on my fuel dispensing system. 470-5 (10 micron) Fuel Tank Filter is the standard filter (flows 25GPM) and they also have a water blocking filter called ?Water-Block? Fuel Tank Filter element. The globe is transparent so you can see any water or debris in the bowl. They are both throwaway filters. Typically inexpensive and available at a number of farm supply stores. We use the same filter system on the airpark fuel system - have been for many years with no problems.
Pilot135pd 04-09-2020 04:47 PM
That?s exactly what I?m looking for and they have them in stock locally. Thanks !
RV10Man 04-09-2020 06:08 PM
That's the filter I use too.
Pilot135pd 04-09-2020 06:10 PM
They didn't have the IN/OUT size I wanted locally so I ordered the fuel filter, the water filter, and some spare filters and o-rings online. Should have it all by Tuesday, Thanks !!
rocketbob 04-09-2020 06:17 PM
https://www.ruralking.com/fuel-tank-filter-1-npt
Pilot135pd 04-09-2020 06:21 PM
Originally Posted by rocketbob (Post 1421048)
That store is out of stock too. Found it in Kansas. Thanks.
rag 04-10-2020 08:55 AM
I should have mentioned to purchase the filter bowl wrench too. A large slip lock pliers will work, but tends to damage the bowl.
Pilot135pd 04-10-2020 10:02 AM
Saw it and ordered it too, thanks !!
JonJay 04-10-2020 10:05 AM
If you use the ?water absorbing? type, make sure you follow the guidelines on filter changes. They trap water and will rust over time, allowing small particles of rust through.
