VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Loctite on AN fitting B nut (https://vansairforce.net/community/showthread.php?t=181208)
JoopSJ 04-09-2020 03:11 AM
Is it good or bad practise to add blue loctite to the B nuts of AN fitting. considering the amount of vibration it seems like extra security to prevent the nut from loosening up.
Or is the standard tightning procedure sufficient to prevent this happening.
Thank you
noelf 04-09-2020 04:38 AM
Bad idea. Don't do it.
PCHunt 04-09-2020 05:27 AM
I don't think there is any mention of loctite, or any other thread locking compound in AC 43.13. Flare fittings have been around for a long time now, and loosening of them is not a known issue.
Failure to tighten properly, however, is a human issue.
The old WWII MS-series, the current AN-series, and the 37-degree industrial fittings don't require loctite.
Most flare failures are due to improper flare formation during tube construction, or improper torque during assembly. The usual torque mistake is OVERtorque, which results in cracking of the flare on the tube.
IMHO, no need for loctite, but learn how to form the flare properly (Lots of important details here), and don't overtorque when installing.
My Two Cents, YMMV.
Red Mtn flyer 04-09-2020 06:09 AM
+1
What PC said. Simple joint but takes practice.
9GT 04-09-2020 06:57 AM
They are assembled dry,,,no teflon tape either. Loctite hardens over time. You would not want a chunk of it break off and make its way to your engine.
JoopSJ 04-09-2020 07:14 AM
OK, thanks all,
Yes, I am familiar with the AC.43.13 guidelines.
I will stick to that.
(Sometimes I tend to overthink or overdo things)
FinnFlyer 04-09-2020 07:34 AM
No harm in questioning "best practices", especially if it leads to an understanding of why it's considered best, recommended or required practice.
Finn
TS Flightlines 04-09-2020 08:43 AM
What has more vibration---your IO360 or a CAT bulldozer---careful with the answer. Think about it--
Enough said---
Tom
Ron B. 04-09-2020 09:04 AM
Enough said---
Tom
Tell you what , your butt knows the difference.
fixnflyguy 04-09-2020 10:50 AM
Torque seal and forget
As your building, or re-building, a good practice is to apply torque seal which is a great visual inspection aid that will validate 2 things..one, that you have torqued it for final time, and second, it will visually let you know if it is loose, or has been loosened during inspection or maintenance. I torque seal mine at the B-nut and the ferrule /tube. I prefer bright orange, but lots of colors available. In fact, I do the same for every bolt on the plane.
PilotjohnS 04-09-2020 11:42 AM
Just me
In the 70's, during my A&P school, I saw some B-nuts with safety wire holes and they were safety wired.
For me, I am planning to torque to spec and then torque stripping.
Tankerpilot75 04-09-2020 01:35 PM
What about EZ Turn lube on flair fittings. The product sold through Aircraft Spruce is supposed to be, I thought, specifically for this purpose.
BobTurner 04-09-2020 01:45 PM
NO. The torque spec is for clean, dry threads. Adding a lubricant will result in the loss of the expected friction, so the threads will be over-torqued.
EZ turn is for pipe threads, where the seal is within the threads, and ideally metal to metal. Most people add a sealant/lubricant to the threads to ?help?. There is considerable debate as to how well EZ works as a sealant in fuel lines.
Steve Melton 04-09-2020 02:49 PM
I use no loctite but triple torque.
1. tighten to torque value, then loosen.
2. tighten to torque value, then loosen.
3. tighten to torque value, final.
DanH 04-09-2020 03:05 PM
EZ Turn is a lube to be used very sparingly in a fuel valve...and it's arguably not the best choice for even that limited use.
Remember, EZ Turn is thick, sticky, and insoluble in fuel. A little dab loose in the fuel system can plug a carb jet and either kind of fuel injection.
N941WR 04-09-2020 03:11 PM
When I do a tech inspection, if it doesn't have torque seal on it, it isn't torqued.
DanH 04-09-2020 04:18 PM
Excellent. It means you would pick up a wrench and check them for real.
F1 Rocket 04-10-2020 01:59 PM
I’ve had mixed results with Torque Seal. When checking some B nuts in my fuel system I discovered a few were loose after a few years, even though the Torque Seal looked perfect. What I found was that the hardened Torque Seal was slipping around the threads. So I don’t trust it much anymore and always put a wrench on these fittings to make sure they are tight.
PilotjohnS 04-10-2020 02:25 PM
Torque Seal
There was a recent article in Sport Aviation or Kitplanes showing torque seal applied but was kind of messy. I never do it this way, neatness counts. To avoid the torque seal slipping and giving a false positive torque reading, I run a very nice bead all the way along a line from the hose barrel to the flange nut on the fitting. This way, if the b nut rotates, it will break the torque seal on the flange nut. Here I found neatness counts. It the torque seal is messy, it is hard to tell if it broke loose. And if the torque seal does not have good adherence to the flange, it wont break when rotated.
