VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Loctite on AN fitting B nut (https://vansairforce.net/community/showthread.php?t=181208)
PilotjohnS 04-09-2020 11:42 AM
Just me
In the 70's, during my A&P school, I saw some B-nuts with safety wire holes and they were safety wired.
For me, I am planning to torque to spec and then torque stripping.
Tankerpilot75 04-09-2020 01:35 PM
What about EZ Turn lube on flair fittings. The product sold through Aircraft Spruce is supposed to be, I thought, specifically for this purpose.
BobTurner 04-09-2020 01:45 PM
NO. The torque spec is for clean, dry threads. Adding a lubricant will result in the loss of the expected friction, so the threads will be over-torqued.
EZ turn is for pipe threads, where the seal is within the threads, and ideally metal to metal. Most people add a sealant/lubricant to the threads to ?help?. There is considerable debate as to how well EZ works as a sealant in fuel lines.
Steve Melton 04-09-2020 02:49 PM
I use no loctite but triple torque.
1. tighten to torque value, then loosen.
2. tighten to torque value, then loosen.
3. tighten to torque value, final.
DanH 04-09-2020 03:05 PM
EZ Turn is a lube to be used very sparingly in a fuel valve...and it's arguably not the best choice for even that limited use.
Remember, EZ Turn is thick, sticky, and insoluble in fuel. A little dab loose in the fuel system can plug a carb jet and either kind of fuel injection.
N941WR 04-09-2020 03:11 PM
Originally Posted by fixnflyguy (Post 1420899)
As your building, or re-building, a good practice is to apply torque seal which is a great visual inspection aid that will validate 2 things..one, that you have torqued it for final time, and second, it will visually let you know if it is loose, or has been loosened during inspection or maintenance. I torque seal mine at the B-nut and the ferrule /tube. I prefer bright orange, but lots of colors available. In fact, I do the same for every bolt on the plane.
When I do a tech inspection, if it doesn't have torque seal on it, it isn't torqued.
DanH 04-09-2020 04:18 PM
Excellent. It means you would pick up a wrench and check them for real.
F1 Rocket 04-10-2020 01:59 PM
I’ve had mixed results with Torque Seal. When checking some B nuts in my fuel system I discovered a few were loose after a few years, even though the Torque Seal looked perfect. What I found was that the hardened Torque Seal was slipping around the threads. So I don’t trust it much anymore and always put a wrench on these fittings to make sure they are tight.
PilotjohnS 04-10-2020 02:25 PM
Torque Seal
There was a recent article in Sport Aviation or Kitplanes showing torque seal applied but was kind of messy. I never do it this way, neatness counts. To avoid the torque seal slipping and giving a false positive torque reading, I run a very nice bead all the way along a line from the hose barrel to the flange nut on the fitting. This way, if the b nut rotates, it will break the torque seal on the flange nut. Here I found neatness counts. It the torque seal is messy, it is hard to tell if it broke loose. And if the torque seal does not have good adherence to the flange, it wont break when rotated.
