VAF Forums
-   -   Source for steel AN fittings (https://vansairforce.net/community/showthread.php?t=181201)
UnPossible 04-08-2020 08:06 PM
Hey - I am looking for a steel AN823-8 fitting and Spruce is backordered until early June. I tried a search, but came up empty. Are there any other online suppliers I should check for steel AN fittings?
Jason
Mike S 04-08-2020 08:17 PM
Check with Tom at TS flightlines.
emsvitil 04-08-2020 08:25 PM
https://www.anplumbing.com/adapters/...-adapters.html
n82rb 04-08-2020 08:30 PM
my local hydraulic hose shop stocks them at a pretty good price.
bob burns
RV-4 N82RB
VA Maule 04-08-2020 08:32 PM
Any shop that makes hydraulic hoses usually have quite a selection of what they call JIC fittings exactly the same thing as steel AN's
pazmanyflyer 04-08-2020 09:37 PM
Find a Parker Hose Shop. They will most likely have it there in the store. I have 3 locations here in Phoenix and they are all well stocked. They also carry Earl's fittings.
TS Flightlines 04-08-2020 11:14 PM
Morgan, JIC and AN are not the same, even though they look or resemble each other. NOT starting a flame war here, but different machining, class 3 threads and some different materials are the differences.
BUT---for experimentals, JIC adapters work just fine
Tom
pa38112 04-09-2020 06:29 AM
Summit Racing usually has them
John Tierney 04-09-2020 08:22 AM
Also try Pegasus Auto Racing: https://www.pegasusautoracing.com/
They have a surprising amount of aircraft stuff.
UnPossible 04-09-2020 09:06 AM
I looked at Pegasus last night, but I only could find AL fittings in the size I am looking for. I need to order my FWF Oil and fuel lines... I'll call Tom and see if they have what I am looking for.
Thanks for all the suggestions
