Fuel flow
RV-14A. Andair electric pump with wing-root mounted Andair gascolator (70 micron mesh). 1.5 gallon fuel in the the tank. Fuel line disconnected at the FM-150 fuel servo and tied up on that level.
Level flight attitude and 15 degrees nose up (mains on the floor and tail on the floor). Both attitudes: around 36 GPH. Please put your mains on blocks and tail down to get to 20 degrees or more nose up. I would love to have those fuel flow numbers. Will be interesting to know what is the degrees nose up at Vx (70 kts). Maybe 20 degrees, maybe more. |
Andair fuel flow
I got around 50 GPH when I did my fuel flow test at just over 16 degrees nose up, hose disconnected just before the fuel servo. The Andair data sheet says open flow of 55-60 GPH @ 5 PSI.
http://www.andair.co.uk/product/boost-pump-px375-tc/ |
| All times are GMT -6. The time now is 03:02 PM. |
