VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Externally regulated AUTO Alternator (https://vansairforce.net/community/showthread.php?t=180935)
pecanflyboy 03-31-2020 03:08 PM
There is a ton of information and opinions about which auto alternators are best and whether to use an internal or external voltage regulator. I've come to the conclusion that I want a 50+amp auto alternator, without internal regulation. I'm using an external voltage regulator.
Within those parameters, I'd like Lester numbers or Autozone numbers for alternators that fit the description. These alternators should have a Field post and a B+ output post.
I'm having a difficult time finding an alternator without an internal regulator, and I don't want to modify it for an external voltage regulator.
Thanks in advance.
Mike S 03-31-2020 05:15 PM
Good luck finding one-----they probably exist, but not common.
moosepileit 03-31-2020 05:15 PM
http://www.vansairforce.com/communit...8&postcount=30
Delco Remy 14158 should do the trick http://www.delcoremy.com/product/product-details/14158
Or try Denso 2100244 http://www.rockauto.com/en/moreinfo....167713&jsn=609
pecanflyboy 03-31-2020 07:55 PM
Originally Posted by moosepileit (Post 1418567)
Thanks Moose. Hours of reading and you solved my problem. I wish there was a way to search these alternators by features and not year make model.
JC
pecanflyboy 04-01-2020 08:32 AM
Well, that was fun. I literally looked at all the alternator pictures on Autozone, trying to find the smallest, CW rotation, externally regulated unit available. What I've discovered is that if you want small with internal fan, it's going to have an internal regulator.
The 14824 is the most compact unit delivering 55amps, internal fan, with a CW rotation. The stator has only 100mm diameter. I has a 3 pin plug with an internal regulator.
I actually have one of these in hand. I guess I'm going to have to figure out how to remove the internal regulator.
lr172 04-01-2020 09:00 AM
I have used the 14158 on both my planes with good success. Correct rotation, 50 amps and externally regulated. Pulley size is optimized for the smaller lycoming flywheels, but RPMs should still be within range for larger pulley flywheels. If you cross match the ND number, you will find a unit remanufactured by ND for about $70 at summit racing or rock auto. That should provide greater reliability than the general aftermarket.
Larry
pecanflyboy 04-01-2020 09:57 AM
Larry
Thanks Larry,
I've looked at that one. You have to be careful to get the correct fan, as I've seen the 14158 with fans in both directions. Trying to run it down on Summit.
JC
lr172 04-01-2020 10:24 AM
Originally Posted by pecanflyboy (Post 1418715)
Thanks Larry,
JC
Yes. However, I installed the one with the wrong fan on my 6. 650 hours of trouble free service, so suspect that it is not critical. I am confident the ND reman will have the correct fan.
Larry
Sam Buchanan 04-01-2020 12:20 PM
Thanks Larry,
JC
The alternator doesn't care electrically which way it rotates and it is doubtful the presence of the correct fan or even a fan at all is a big deal in our application. The 35a alternator Vans sold for years was delivered without a fan and overheating wasn't a problem. Many of us back in the day installed a blast tube aimed at the rear of the alternator.
Jrskygod 04-01-2020 03:56 PM
pecanflyboy - I wrote an article for Kitplanes magazine early last year that explains how to modify the alternator for external regulation. You might check the article out and see if you wish to take on the task of modifying the alternator.
