VAF Forums
-   RV Photo/Video URLs (https://vansairforce.net/community/forumdisplay.php?f=71)
-   -   Mess Free Oil Change Possible? (https://vansairforce.net/community/showthread.php?t=180893)
sjhurlbut 03-30-2020 08:11 AM
There are a lot of special tools out there to try make the oil change cleaner on a Lycoming. Is mess free possbile? Not really hahaha
https://www.youtube.com/watch?v=SdRCiU-I2XE
lndwarrior 03-30-2020 09:22 AM
Great
Very nicely done - and very thorough!
Mark Dickens 03-30-2020 09:45 AM
One thing I do is elevate the tailwheel so that all that oil in the back of the oil pan flows forward and drains out with the rest of the oil. Makes it easier and cleaner to do the oil screen too
sjhurlbut 03-30-2020 09:48 AM
For sure - thanks for adding. I used to do that too when I had a tailwheel jack
Bavafa 03-30-2020 09:51 AM
Great video.
Just curious which model challenger oil filter are you using with your up right oil filter adaptor and how long have you been using that? Any feed back on it would be great.
I have the B&C up right adaptor which calls for CH48108 oil filter. These have an anti drain back so they don't drain out between each start.
cfiidon 03-30-2020 10:03 AM
I punch a small hole in my Tempest filter adjacent to the safety wire ring and let it drain overnight. The next day I put a piece of tape over the hole and remove the filter with minimal or no drip.
The tape over the hole prevents any remaining oil from dripping out once I turn the filter over after removing.
It would be nice if your challenger filter had a "relief" valve.
sjhurlbut 03-30-2020 10:24 AM
Aircraft Spruce shows directly which filter to replace the 48108. I've been using these for years on several RV models. I really like the size (smaller diameter), cooling fins, and looks. And no more cutting filters open.
Originally Posted by Bavafa (Post 1418222)
Great video.
Bavafa 03-30-2020 10:44 AM
My understanding is that some of the models have the relief valve, unless by relief valve you mean a drain valve from the body.
sjhurlbut 03-30-2020 11:02 AM
yes
Yes some have relief valves as indicated in the product description. Drains back into engine.
Think he was meaning an actual valve to open and drain it before removing it. None have that for good reason.
DeeCee 57 03-30-2020 12:23 PM
well, nothing really new in that vid but, as usual when made by Stu, pretty :cool:
Now one item which is working pretty well for me, is the kind of disposable BBQ drip pan tray such as those https://www.walmart.ca/en/ip/AIHOME-...RD4IL8SMGZ0CVP
And yes, it now works mess free :)
