Right-hand Mag Removal Advice
I've got to remove the right mag on my IO-540 to replace a leaking gasket. Any advice or gotcha's I need to be aware of during the removal and subsequent re-installation? I've got the Slick L-1363C Overhaul and Maintenance manual plus Tim Olson's version of the SkyRanch mag instructions, but never having removed a mag before just want to make sure I'm not missing anything.
Watch for falling FOD
I'm always concerned about dropping a piece of hardware into the open mag hole during removal and re-install.
I remove the top fastner and hold down block completely before removing the bottom fastner when removing a mag and do the bottom first when re-installing. I cover the open mag hole with a clean rag while the mag is out. If you happen to have a mag hole cover (like the ones get if you have a Lightspeed ignition) that's even better. |
Before you remove it, set the prop at 25 degrees BTDC on #1 (or whatever your timing says). Be sure it is #1 firing stroke, not #1 exhaust stroke by putting a finger over the spark-plug hole and feeling for compression.
mark on the rim of the mag with a sharpie or a piece of masking tape or something where the hold-down clamp parts touch on the rim of the mag. Sometimes you can see the compression marks in the paint and you don't need to mark it. Then, while the mag is out, DO NOT turn the prop. When you reinstall it, with the special pin that locks the mag in the firing position, you can pop it in matching the marks to the hold-down studs, put the hold-down blocks and nuts on finger tight, and hook everything up, knowing that you will be really close to the correct timing. BE ABSOLUTELY SURE YOU PULL THAT PIN OUT BEFORE YOU MOVE THE PROP. Set the final timing with the buzz box. Normal safety procedures apply, i.e. disconnect all the ignition leads or pull the plugs. |
Thanks fellas! With regards to inserting the T118 timing pin, is that something I should try to do as I'm puling the mag off (if that's even possible) or wait until it's been pulled completely off the engine?
The mag data plate will indicate left or right handed rotation (not the same as left or right mag position on engine). That tells you which hole to insert the pin into. Also, it was pointed out by Dave Howe that 6-cylinder mags apparently have a different drive coupling than the 4-cyl drive gear that I am familiar with, and apparently it can be tricky to keep the coupling assembled while inserting without having a part fall into the sump. I wasn't aware of that. All my suggestions for setup to make it easy to get the timing right on re-install still apply, but would be good to hear advice on how to keep the coupling together right. |
The 6 cyl has the rubber drive cushions, be careful not to let them fall into the engine, pull the mag straight out very slowly/gently, the rubber cushions will probably stay in the mag drive inside the engine but you never know. I like to install new rubberss if the engine has very many hours on it. Glue the new cushions on the mag before installing.
Larry |
| All times are GMT -6. The time now is 05:48 PM. |
