Fuel systems and auto parts
I will use auto fuel. I thought this was straight forward, but I have found out by now (thanks in large part to this board :) ) that this is not as straight forward as I thought. For instance, Ellison TBI cannot be used due to chemical incompatibility between auto fuel and materials used in the TBI.
More in general terms I also got the understanding that AN fittings not neccesarily are compatible with autofuel. I have no idea if this is "just the specs", ie they are only spec'ed for AVGAS but there are no physical or chemical incompatibilities with auto fuel, or they are only spec'ed for AVGAS because there really are chemical incompatibilities, like the Ellison. I also wonder if there are any difference bewteen fittings vs AVGAS and Jet fuel. Maybe it is better to use automitive fittings? |
Auto fuel
AN fittings work fine with auto fuel.
That's a shame that the Ellison TBI does not work with auto fuel. I read that on their website, but they don't say which components will have trouble. |
Auto fuel?
This is a first! At least here and right now, there is no reason to use auto fuel! I am filling up my airplane with 100LL for less per gallon than my wife's car which takes premium. ($3.69 vs 3.79.) Since the few airports around that sell auto gas charge more than the local service stations, 100LL is a bargain. I never thought I'd say that.
Bob Kelly |
Won't last long that way either, enjoy it for now!!
Fuel at my home base is always at least a dollar a gallon higher than auto fuel.
I emailed Ellison FLuid Systems. They said it was rubber gaskets and things that would have it. They also said they had no plans now or in the future to change the materials affected. Good to hear that AN fittings work :) |
Bill Jepson PS. and YES AN fittings work FINE! I wonder where these rumors get started! |
| All times are GMT -6. The time now is 08:55 PM. |
