VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Bendix DUAL MAG model hole in the top (https://vansairforce.net/community/showthread.php?t=180599)
Gyrodoug 03-19-2020 01:22 PM
I wish posting pics was easier, or I was smarter... That being said... on the Bendix 10-385124-110 model of magnetos, there are screw holes with plugs. But... on the top one of the holes in mine is NOT PLUGGED. I sorta panicked. Then I Google it looking for parts/spare plugs, I see a mag advertised - ALSO missing the same plug.
Can this possibly be for a reason? Venting etc? The un-nerving part is I can actually see the guts/gears inside. I can't imagine this is OK.
THOUGHTS?
Jpm757 03-19-2020 04:37 PM
Some of those magnetos were pressurized, that could possibly be what the hole was used for.
cajunwings 03-19-2020 04:49 PM
Mag hole
Many of the Bendix mags had just a simple black plastic plug with a flat blade screwdriver slot in it. They used a solid plug in the top hole and the same plug on the bottom, but with drilled vent holes. Any mag repair shop will have them. Ask a mechanic for a loose one they may have.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Gyrodoug 03-20-2020 08:04 AM
Thanks for the feedback fellas.
