I have always put a relay (contractor) on the alternator output when working with internally regulated alternators. At best, they have failure modes that can cause uncontrolled output, and some self excite and intentionally output without an input on the control line.
My alternator switch then controls both the control line (maybe field? )of the alternator and the output. Further I put a OV module on the power for the relay coil which will crowbar the power via the Alternator Control CB and ensure that the alternator is offline faster than I could even think of reacting. Contactors are mechanical, and in electrical terms very slow, maybe to slow to prevent some damage. But, practically the best that I can do, given the cost of other options. |
After reading the responses as well as a similar thread from 2012, I concluded that I have a self-exciting automotive style alternator that cannot be shut down with the master switch in flight, and that others are set up this way too and are either OK with it, or unaware of it. As the frightening posts by Allan and Joel show, it is unsafe if you can?t shut off your main bus in flight. The master switch should work just like it works on a certified airplane. I have ordered an alternator kit from Vans for $495 that I expect to fix my issue. PS: I wanted to post a photo of my alternator connector but couldn?t figure out how. My pics are on my iPad and in Google Photos, but where do I get a URL? I am new to online forums
Also I didn?t understand Allan?s explanation of how disconnecting the battery via the master switch caused his alternator output to skyrocket. Why didn?t the regulator just try to maintain the proper voltage on the main bus? I had no such problem as I was discovering that my master switch wasn?t shutting off the bus
Also I didn't build this aircraft, so many of the things I would have implemented were not in place. Thanks, Allan |
stop the prop
Hi Allan - I would have never thought to stop the prop in this scenario, makes perfect sense now that I hear it.
Runaway alternators do seem to be a failure mode that comes up repeatedly with various impact - mainly smoke and fried electronics. I really like that I feel like I have another tool in the toolbox to deal with that unlikely scenario. |
Lary |
Larry |
Problem solved
Just replaced my car alternator with a Plane-Power unit from Vans for about $500 total, and now I can shut it off with the master switch, giving me piece of mind, plus I saved almost two lb with lighter mounting brackets and lighter alternator, making the trouble and expense less painful. Anyone want a used, working automotive type unit cheap?
| All times are GMT -6. The time now is 03:03 PM. |
