VAF Forums
-   COMM (https://vansairforce.net/community/forumdisplay.php?f=38)
-   -   Garmin GTR200 Mic / Intercom Issue (https://vansairforce.net/community/showthread.php?t=180406)
jelliott82 03-13-2020 03:26 AM
Hello
My Garmin GTR200 Mic Input / Intercom function isn't working. When I connect my 2x Bose A20 headsets and try to talk to one another there is no mic audio transmitting across the intercom from either headset. Are there any specific settings or configuration I should be setting on either the Bose A20's or the GTR200 / G3X, or should this just work and I need to review my wiring? The wiring was completed as per the wiring schematic in the G3X installation manual .. unless I made an error during the install.
I haven't yet tried the mic while transmitting.
Jonathan
jliltd 03-13-2020 06:02 AM
Did you enter the GTR 200's "Configuration Mode" and go to the "Audio Setup" page to enable the intercom function? This is found in section 3.6.4 and 3.6.4.3 of the GTR 200/200B Installation Manual.
To enter Configuration Mode on the GTR 200, starting with the unit powered off press and hold the small rotary knob and then power on the device. Release the small knob when the display activates.
You mentioned using the G3X installation manual for your wiring but make sure to also get a copy of the "GTR 200/200B Installation Manual".
You will love this unit once it is up and running right.
Pmerems 03-13-2020 10:54 AM
Power sequence
I have a Zulu and clarity aloft headset setup with the GTR 200. I have to turn on the Zulu power after the GTR is powered on for the intercom function to work. Not a big deal.
g3xpert 03-13-2020 12:24 PM
GTR 200 Intercom
Originally Posted by jelliott82 (Post 1414194)
Hello
Jonathan
Jonathan,
We take it this is a single COM installation with no audio panel. As others have mentioned, the intercom must be enabled in the GTR 200 for it to work. There are some other troubleshooting steps we can work through if the intercom is enabled and not working. The intercom can be enabled by powering on the unit while holding in the inner knob, and selecting Audio Setup.
Justin
