Anti-chafe sleeving for wires
Can anyone share best practices around using anti-chafe sleeving for (non-engine compartment) wire runs? I'm talking about this stuff:
split loom
Lacing or tie wraps is the norm if properly supported and protected by finish panels or such. If you cover all your wire runs unnecessarily it becomes a problem later if some maintenance issue comes up and you need access. The weaved sleeving is appropriate for things like EFIS / panel harnesses. Some folks use the ribbed tubing in areas to prevent wire bundle sagging, but with accessible at each end if wiring maintenance is required.
Weave
I use heat shrink where bundles go through snap bushings. I used weave in a few places. Close the ends with heat shrink or self fusing silicone tape.
This is not so much anti-chafe as it it for general wire management. I used this extensively in my build (firewall aft). I use either heat shrink or self-fusing silicone tape to terminate the ends. I size it so that I need to expand the braid a bit to fit the wires; it will collapse and hold the bundle snugly. I used it for long, snaking runs. Short runs behind the panel are laced.
You can do the same thing with lacing cord or cables ties, but this is a mess-free solution that keeps the bundle nicely together, but it remains flexible and can easily be threaded thru grommets, etc. |
I'm just running the laced bundles through the plastic bushings and calling it good. If there's a location where chafing appears to be possible, I'll find a way to clamp the bundles down. I don't use conduit anywhere.
I do plan to use some sort of wire protection FWF for some things, but that's all TBD at this point. Dave |
https://www.steinair.com/
https://www.wirecare.com These are 2 Great places to buy this kind of thing. I used it on every wire run I could put it on. Heat shrink the ends. Get the smaller ones cuz they expand a fair amount. Mike |
Too much work to use everywhere in an airplane on all wires, too much added weight that does not add value, added expense for the entire airplane, and more time spent building that does not decrease maintenance time. |
Some of my pre-made harnesses came with it (Dynon SV EFIS-to-autopilot servos, e.g.), but I wouldn't use it on any of my own harnessing. Lacing cord is the way to go :) |
I won?t be using it in this build. Just sticking to regular tie wrap/lacing and appropriate grommets/bushings and clamps. |
| All times are GMT -6. The time now is 04:43 PM. |
