VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   need connector or mil spec cannon plug for PTT (https://vansairforce.net/community/showthread.php?t=1801)
mark manda 06-01-2005 10:08 AM
anybody have a suggestion or better yet, a picture,link and part number from a supplier that makes a quality connector for the (removable) passenger stick? Looks like nine wires or pins.
Or a supplier with cannon plugs. or I can go the bulky sub connector route.
thanks mark
flyerfly 06-01-2005 04:20 PM
connectors
Hi Mark,
These connectors are not cheap but it is what we used when I used to engineer aerospace components. I am sure they have something that would work for you. You could also look at digikey or something.
http://www.spacecraft.com/
Jon
fehdxl 06-01-2005 06:24 PM
why?
Hi Mark,
I'm not a builder yet, but I've been lurking around these sites for a while. I can't find the exact post, but I remember someone saying that they put the passenger's push-to-talk somewhere on the panel...not on the stick. This way an inexperienced/new passenger couldn't inadvertently press it; as well as the person sitting there without a stick could also talk on the radio if need be. In fact, I think the PTT was hidden in an inconspicuous place on the panel that was not obvious to a new person, but yet easy to operate once briefed where it was.
Just another perspective.
-Jim
mark manda 06-01-2005 07:28 PM
thanks jon, thanks jim.
mark
thanks paul, thanks gil. I found a Newark catalog in my den so I'm sure the racecar stuff years ago came from them. good link. I'll check the digikey link, heard lots of good stuff about them.
I hope I'm not adding a bunch of weight.
Ironflight 06-02-2005 09:26 AM
Try DigiKey
Mark - try www.digikey.com
They have just about every electronics component you can think of in their catalog, and the prices aren't bad. I know that our prototyping folks use them a lot for small orders.
Paul Dye
az_gila 06-02-2005 09:07 PM
From one of my previous posts about strobe connectors..... gil in Tucson
These Micro-X connectors from Newark electronics make for nice small connectors, which are low-cost and weatherproof.
A picture of one is here...
http://www.newark.com/productimages/...rd/4079284.jpg
This page lists them all. The nylon ones are under $5 and are a good alternative to the $$$$ metal mil-spec type.
http://tinyurl.com/6zwzr
Update..
This Newark web page has a better picture of these connectors....
http://tinyurl.com/6jgo4
These also make neat connector for the trim servos and stick wiring. They have a postive lock and won't vibrate off.
gil in Tucson
