VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   EarthX Multi-use Battery Box Dimensions (https://vansairforce.net/community/showthread.php?t=180093)
JordanGrant 03-03-2020 09:14 AM
After searching on VAF and the EarthX website, I could never find the actual dimensions of the mounting holes for the EarthX battery boxes. I just received mine, so I'll post the data here for others that may need it.
Model: BB-MU "Multi Use Battery Box for E case or PC680"
There are 6 holes in the aluminum mounting box, arranged in the same manner as the RV-7 "standard" firewall-mounted battery box, i.e. two vertical rows of 3 holes each. I don't know if the dimensions are the same, though, so I'll just put them here for reference:
The two vertical rows are spaced 8" apart. The top holes are 2" from the middle hole. The bottom hole is 2 5/16" down from the middle hole.
I'll even try to do a little ASCII drawing to depict it:
O <--- 8" ---> O
2"
O <--- 8" ---> O
2 5/16"
O <--- 8" ---> O
Hopefully that's helpful to someone else deciding what battery box to order.
scrollF4 03-03-2020 10:03 AM
Did you call them and ask? Their customer support is great.
JordanGrant 03-03-2020 06:55 PM
I've heard nothing but great reports about customer support. I have not called, but I'm sure they would be happy to give that info over the phone if I did. Maybe my post above will save someone the trouble of making that phone call, though.
