VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   Removing Fuel Lube from Gaskets (https://vansairforce.net/community/showthread.php?t=18004)
FlyerJumper 05-24-2007 09:06 AM
Any recommendations for a solvent/cleaner that will remove fuel lube (EZ Turn) without damaging gasket material? More specifically, I'm wondering about the fuel cap gaskets.
Mark Burns 05-24-2007 09:18 AM
Fuel lube solvent
I haven't found anything that will "cut" it.
I'll be watching this thread to see if anyone has.
Just wiping it off with lint free rags is what I do when I need to remove it from something, and this doesn't work real well.
It's made out of kryptonite cream I think.
Mark
FlyerJumper 05-26-2007 10:51 PM
Anyone?
Bueller...
Bueller...
Bueller...
:D :D :D
dan 05-27-2007 04:24 AM
Why do you want to remove the fuelube in the first place?
FlyerJumper 05-27-2007 07:54 AM
well...
There may have been some dirt, aluminum shavings, dead bugs, and some other stuff I have yet to identify that made their way on there when I wasn't looking... ok, maybe it happened when it rolled across the floor and behind the tool chest... details! :o
G-force 05-27-2007 04:25 PM
I dont have any fuel lube around to try, but I would guess a tricloroethane solvent (Valco 184, printer ink solvent, etc) would work. Not much it wont disolve. Or perhaps if it is silicone based lube, a silocone solvent (try an automotive paint store) would work.
yakdriver 05-28-2007 08:29 AM
Lacquer thinner works great. Don
