Average cure time for pro-seal
Hi gang,
I know that it depends on the temperature, but what?s the average cure time for pro-seal. I?m retrofitting return line bungs in my fuel tanks, so it?ll be a very small area that I?m pro-sealing. The forecast in my area is calling for highs in the mid and upper sixties to lower seventies and lows in the low to mid forties this week. |
Cure time
When you can rub a baggie on proseal and it doesn?t stick it?s cured enough for service
| All times are GMT -6. The time now is 11:43 AM. |
