VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Wire Labels (https://vansairforce.net/community/showthread.php?t=179423)
GalinHdz 02-15-2020 08:48 PM
Originally Posted by John Tierney (Post 1407146)
Brother P-touch PT-D400 for labels (9 mm/0.35") then clear heat shrink.
+1
That is exactly what I did when I built my panel back in 2012. They still look like I just installed them.
:cool:
Pilot135pd 06-15-2020 08:50 AM
So they both work for labeling wires but how about for the avionics panel? I have to rename a few switches. Brother P-Touch PT-D400 is half the price of the Dymo Rhino 4200. Is there that much difference or is it just more modern?
mfleming 06-15-2020 10:32 AM
Originally Posted by Sam_B (Post 1407018)
There?s a cheaper dymo than the 5200, I think 160, and the cartridges are $13 on Amazon. I could check the model number when I?m at the hangar next, but it?s around $20. Google ?kitplanes magazine wire labels? or something like that. All of that said, I haven?t tried it, wiring is going to start next week.
Yes, the DYMO 160 works great with the ⅜" or ?" heat shrink tubing. I think it also works for the ?" tubing but I haven't tried it.
Pilot135pd 06-15-2020 10:38 AM
Wow, that one is even cheaper and available down the street. What about for the avionics panel? It's not completely smooth, does it stick well enough for switch labeling?
mfleming 06-15-2020 10:44 AM
Well I'm using the heat shrink feature...not sure what your asking??
Pilot135pd 06-15-2020 10:51 AM
You mentioned it works for labeling wires with heat shrink tubing but how about for making labels for the avionics panel? I have to rename a few switches.
bbsdad 06-15-2020 11:09 AM
Dymo
The dymo works well but use industryel labels that stick better. Or you can get white or black on clear. Then spray on clear paint looks good and will last long. It?s the way I?m going. Just my 2cents.
mfleming 06-15-2020 11:26 AM
Personally I plan on using clear decals and spraying a clear coat on top for my panel labeling. I wouldn't use the label maker labels for my panel.
If you're talking about behind the panel, I would use bbsdad's advice and use an industrial adhesive label and I'm sure you could find some that work in the Demo 160.
FinnFlyer 06-15-2020 05:39 PM
The 1/4" A18051 heat shrink tubing works OK up to 22 or 24 AWG. For 26 and higher the tubing doesn't shrink enough to really grip the wire.
The Dymo LabelManager 160 likes to waste label tubing (and other label material). Type in as many as you can (a space or two between labels) before printing, print and then cut them with scissors. Of course you can hand-write on the wasted blank pieces of tubing. The 5' was not enough for all my wiring -- had to buy a second cartridge. Tempting to not have the tube sticking out (clear the opening) before printing but often will wrap around the roller and waste even more.
The Dymo LabelManager 160 I bought did not work out of the box. I had to take it apart and figure out how to get the drive mechanism working.
Finn
RicoB 06-17-2020 09:59 AM
+1 Dymo and the aftermarket cartridges.
works great!!!
