VAF Forums
-   RV-7/7A (https://vansairforce.net/community/forumdisplay.php?f=7)
-   -   Proseal T-708 tank stiffening ring? (https://vansairforce.net/community/showthread.php?t=179231)
FlyGuy65 02-03-2020 04:13 AM
Fuel tank stiffening ring for access cover. Plans say sealant not needed, but I keep hearing “Proseal is cheap at this point”. I can understand why it’s not needed as the whole area will necessarily be sealed later - any reason to seal it?
Thanks!
Ralph Inkster 02-03-2020 10:25 AM
Your choice.
I chose to seal it on all the tanks I did. Same reason I choose to lay a seam on all inside flanges.
GeoffP 02-03-2020 12:01 PM
I didn't seal it. Once the access cover goes on and is sealed as per plans you shouldn't have leaks from that area.
