3400 MFD Screen Glitch Help
I pulled my 7 out tonight to get back into the air and after starting up my right 3400 MFD screen would not boot up.
It was jumping all around with black and white lines running up and down on it. It done it the other day but rebooted to normal. My 3400s screen have been flawless and the customer support from Rob is outstanding. I am going to pull the screen to make sure I don't have any loose wires, etc. Is there anything else I should be looking at before shipping it to Advanced Flight? Thanks Darren Kerns RV7 N599DT |
I had a similar issue. There are a couple ribbon cables. Just make sure that they are seated. Shawn @ AFS had a document to walk through the process if you aren?t comfortable.. |
Okay.
Thanks Bob. I am not familiar with that. I will need the document. Thanks Again Darren Kerns RV7 N599DT |
| All times are GMT -6. The time now is 12:32 PM. |
