VAF Forums
-   RV-9/9A (https://vansairforce.net/community/forumdisplay.php?f=5)
-   -   Trim cable sanity check RV-9A (https://vansairforce.net/community/showthread.php?t=178603)
1bigdog 01-13-2020 08:20 AM
I about to order a new elevator trim cable (manual trim) to embed in the center console. I just want to make sure I am seeing things correctly.
Rotating the trim knob clockwise appears to result in nose up, counter clockwise nose down. Correct???
Seems counter-intuitive. I was thinking of having the mechanism reversed since I'm making a new one.
I have only used trim wheels and electric. Is my thinking off?
Thanks for your insight
Mel 01-13-2020 08:25 AM
No, you are not correct. Rotating the knob clockwise raises the tab, which pushes the elevator down, thereby pushing the nose down. Believe it or not almost half of the new aircraft that I inspect has the pitch trim backwards. Of course with manual trim, this is highly unlikely.
1bigdog 01-13-2020 08:30 AM
thanks
Hi Mel
Greatly appreciated.
