VAF Forums
-   RV-7/7A (https://vansairforce.net/community/forumdisplay.php?f=7)
-   -   RV7 with 9 wings? possible? (https://vansairforce.net/community/showthread.php?t=178375)
N59ST 01-05-2020 07:01 PM
I am preparing to start an RV7, It meets our mission perfectly.
With the thought of Experimental Aviation in mind, I wonder since the 9 shares fuselage and empennage, would it be possible to build a set of 9 wings and "swap" wings out for higher altitude X-country trips? I have not put the costs to the calculator, I would imagine the cost of the wing kits (if Vans would even sell them to a 7 owner) would take a long time to recoup compared to the cruise economy improvement. There is the obvious change in wing aspect ratio, slight increase in SqFt., and smaller tanks. Thinking there maybe CG issues also with the wing chord change and the heavier AIO-360 that is planned.
It is just a thought, it is not like swapping wings and re-rigging would be a 30 minute job. Is just more of a theoretical question. The 7 has enough wing and speed, ceiling is very close to a 9 already.
Zuldarin 01-05-2020 07:37 PM
The first time you attempt to install the close tolerance wing bolts will cure you of any thoughts of ever removing them! :-)
Also, the 9 and the 7 have very similar fuselages, but they are not identical.
rmartingt 01-05-2020 07:40 PM
No, you can't install 9 wings on a 7, or vice-versa.
One option might be swappable wing tips on a 7. Properly engineered, they could provide cruise benefits on long flights yet be swapped out for standard tips for local/fun flying. You'd take a g-limit hit with thw cruise tips in place.
But that's a lot of trouble for smallish gains, unless you rwallylike doing that sort of thing and can do it properly. I've thought about at least designing some (or a set of tapered wings) as an educational exercise but I'm an AE by schooling and profession.
dreed 01-05-2020 07:46 PM
Isn't the carry through different on the 9 as well?
Also, as I recall the H-Stab on the RV-9 is perpendicular to the wing and larger than the RV-7, whereas the RV-7 is smaller and tapered toward the outboard tips a bit.
Norman CYYJ 01-05-2020 07:51 PM
Not practical. Buy the 7, it still performs well in the upper teens.
N941WR 01-05-2020 07:51 PM
The empinage is not the same. The HS and elevators are larger on the -9. I was told by "Van's" that on the prototype, which was a -6 with -9 wings, that the slotted flaps blanketed the HS and elevators, which is why the -9 has that big slab of an HS.
The VS and rudder are the same.
As for the wings, fuel tank support brackets are different and may be in a different location and the forward side skins are different. I don't know if the rest spar is in the same location on the -7 & -9. I do know they share the same dihedral but don't know about the bolt pattern.
ty1295 01-05-2020 07:57 PM
Only took me a couple days to get all the wing bolts in, and I magically learned French in teh process. Even if they did fit, I dread ever having to remove or install those bolts again in my lifetime. Let alone do it on a regular basis.
Love my 9, but I don't think the 7 or 9 are different enough that you need "both". If you plan to go upside down go 7 and be done. If no upside down needed the 9 is awesome.
PilotjohnS 01-05-2020 08:18 PM
Others
As others have me tion the 9 and 7 share common parts but are not the same pick your poison, the 7 or the 9. If you cant decide , then pick the 14
Girraf 01-05-2020 08:19 PM
Every theoretical wing swap evolution would probably trigger another phase 1 type of event.
rvbuilder2002 01-05-2020 08:29 PM
Nope
Research center of lift change and pitching moment induced by flap deployment.
